Hi all!
I've been a reader of this forum for a long time, and have been thoroughly enjoying my Nat P's (so has my friend with his, as we built ours together) for over 5 years now. I have another project that's been floating in my head now, and I'd like to ask for a bit of help from you guys.
I'd like to build a TV stand that's an actual "wall" (you'll see in pics), and the "shelf" for the HTPC/receiver I'd like to also use as a subwoofer cabinet (driver would be facing downward). Haven't decided on driver yet, still planning all this.
As you'll see, I've come up with two designs : one on the left, which is what I'd prefer, with integrated speakers; and the other, on the right, with generic monitor speakers on built-in stands.
My questions :
1. Can I use in-wall speaker designs with something like this? The "wall", btw, would be actually made with 2X4's and framed normally (16"), and I'd estimate the dimensions to be roughly 6' by 6' (I say "estimate" because although I did build this in Google SketchUp - which I suck at, I'll gladly admit - the final dimensions are not yet set in stone);
2. What I'd *really* like to do with the wall-mounted speakers, however, is something like the Totem Tribes - Link :
In other words, a really slim enclosure protruding 2-3" from the wall. Would this be a possibility also?
I don't have a set budget, as long as it's not ridiculous.
Much appreciated!
EDIT : I did start a thread similar to this one a while ago, and somebody suggested the Event Horizon's at :
Just wondering if there are newer alternatives since then, or if I can, as per Q1, just do generic in-wall designs.
My questions :
Much appreciated!
