Help design a 3 way crossover, Please.
  • cesarin
    • Aug 2012
    • 6
    I was wondering if I could please get some help designing a crossover diagram and a list of the supplies I would need to build this.
    The speakers are from what use to be a powered Mackie sr1530, but in no longer has an amp. When i got the speaker it only came with the speakers and the cab it does not have a single part from the amp, so fixing the amp is not an option.
    I found the following info not sure if it helps, the original speaker had The following:
    Crossover Points of 700Hz, 3,000Hz
    Freq. Range (-10 dB) 40Hz - 20kHz
    Freq. Response (-3dB) 45Hz - 18kHz
    I found it on the following page.
    Here are the components I have:
    Low
    15’’
    2.5” Voice Coil Diameter
    250W rms (Long term) Power Handling
    16 ohm
    Mid
    6”
    2” Voice Coil
    60W rms (Long term) Power Handling
    8 ohm
    High
    1”
    1” Voice Coil
    25W rms (Long term) Power Handling
    8 ohm
    Thank you!
    This data only lets us throw a textbook crossover at you, which probably won't result in anything that sounds too good.
    • cesarin
      • Aug 2012
      • 6
      So what could I do, what kind of data should I try to get? I was hoping to use the speaker as a personal monitor for a bass player. I think any result is better than dumping the speakers so i would not be extreamly picky on the results.
        Hmm. Have you tried simply wiring up the 15" by itself?
        If we could dig up impedance graphs, we might have a slightly better shot at getting something reasonable, though probably it would be brute-force attemting to force impedance to pretend it's flat (which is what textbook crossovers assume.)
        • cesarin
          • Aug 2012
          • 6
          Ill try just the 15" to see what kind results i get thank you
            If it sounds nasty on the top end, you could try something simple like a 1mH inductor in series. It won't do a lot at 16ohm but it should soften the top end where rough stuff would live and perhaps make it usable.
            If your bass player is looking for detail (it's there - string noise, other little nuances based on how you interact) it may not be as audible as desired without something that plays a little higher, but it may be plenty.
            To be honest though, I would *really* recommend in-ear monitors. It's just too loud, and the noise reduction you get from the good ones is worth the cost of even basic 100% custom IEM's (Ultimate Ear being my reference - my next set will be customs, and I use them just for the daily commute on the train.)
            • cesarin
              • Aug 2012
              • 6
              Cool i will try that do you have a diagram of how the 1mh inductor would look like in series. In ear is definitly in our future plans
              • cesarin
                • Aug 2012
                • 6
                Hi I was wondering if the praphs that I found on the following link would help:
                Thank you!
                  Unfortunately, there's only summed response data there.
                  • cesarin
                    • Aug 2012
                    • 6
                    oh ok, I guess Ill stick to plan B with the 1mH inductor in series. thank you again
                    • Stian-
                      Woofer replacement for Khanspires
                      by Stian-
                      Hello All!
                      Damn, did it again, Rammstein does no good to my woofers or my wallet... :M
                      Ive built and used a set of Khanspires for about 8months, and recently i did some rather expensive upgrades to the crossovers, the speakers was good before with Dayton caps and ordinary...
                      03 January 2014, 11:11 Friday
                    • dawg1161
                      Need Help with a 2 way design.
                      by dawg1161
                      First I would like to thank all who reply.
                      Wednesday morning i get all the supplies i need for the sonosub minus the subwoofer(other active thread).
                      I know that in every post that i read one is not to use a stock crossover, I did not know this until i began reading all...
                      16 August 2006, 00:24 Wednesday
                    • 1Michael
                      Modula MTM with Dual 15" Sealed BassBin?
                      by 1Michael
                      Hello all. Well after having listened to the big RS 3ways for some time I am still left wanting more bass, so I have decided to stop messing around and use dual 15'' bass bins to get some real kick in the chest action. I am looking at the Dayton Series II, ST385-8 with:
                      Power handling: 300 watts...
                      11 April 2009, 16:29 Saturday
                    • Armand
                      Replacing Seas Tweeter Voice Coil
                      by Armand
                      I'm expecting replacment VC's for SEAS H1212 tweeters and was wondering if there are any tips that you all can give me. I ask because I ran into this during a search:
                      ""In case you ever need to replace the voice coil assembly of your tweeter, here is the procedure for re-assembly:...
                      08 July 2010, 06:28 Thursday
                    • NoNoBadDog
                      New Design (in over my head?)
                      by NoNoBadDog
                      I have been trying to come up with a design that makes sense. I think this one does so far but I am a noob so I might be in over my head. What I really want to know is if this one makes any sense. I have no way to measure drivers at this point. I am working on the microphones but don’t have them...
                      04 November 2007, 10:02 Sunday
