Hi! So after a long time, finally decided that this was it and I was to finish building my Monitor Statements Almost finished the cabinets, I put the crossover together from the parts purchased quite a while ago, and noticed two surprises...
1) 51 uF instead of a 50 uF cap... and
2) A 3.6 uF cap instead of a 3.3 uF + .33 uF wired in parallel for 3.63 uF...
So how screwed am I? I've put together the crossover using the above, but I'm about to screw in the crossover and solder the last wires to the cabinet and am having doubts whether these two parts difference will have a significant effect in the end and it would be worth it to reorder the parts :cry:
The 50/51 uF cap is for the mid woofer, and the 3.66 uF is for the tweeter: http://www.speakerdesignworks.com/Mo...allNetwork.PNG
My 1st thought was 50/51, a 2% difference, might not make a huge difference, and for the 3.6 vs 3.63, that's less than 1% difference... But then thought that it might not be as simple as that and might skew things significantly in the end... Thoughts?
