What grade is typically used for speaker cabinets and where do you get it? I see that Woodcraft carries grade BB/B, I also found a seller on Amazon that carries the same stuff at a slightly lower price. Woodcraft indicates that BB/B has one face that may contain patches and knots - is this acceptable for speaker cabinets? (provided there are no voids or loose bits anywhere?) Alternatively, are there any other types of plywood you can use?
The local Menards also carries Baltic Birch in grade BB/CP or something like that - didn't look too bad but it had quite a few knots in it.
Right now I'm leaning toward doing a CLD enclosure, a curved cabinet made of 1/8" thick layers, using hardboard for the damping layer. Maybe 2 layers of plywood, 4 layers of harboard, then 2 more layers of plywood for an overall thickness of 1".
