Hi everyone,
I thought I should give a heads-up on what’s cooking among the spring, summer and early autumn projects and designs.
Here’s a round-up of the tweeters being used together with some of the very best mid-ranges, mid-woofers and woofers from AudioTechnology and ScanSpeak.
From left to right (Picture1):
* RAAL 140-15D Ribbon Tweeter
* ScanSpeak Illuminator D3004/660000 1” Textile Dome Tweeter
* ScanSpeak Illuminator D3004/662010 1” Small Form Factor Textile Dome Tweeter
* ScanSpeak Illuminator D3004/664000 1” Beryllium Dome Tweeter
Here are some detailed measurements of the AirCirc Textile and Beryllium dome tweeters and a comparison between the two:
ScanSpeak Illuminator Textile dome vs Beryllium dome!
Next design to be shared and published is the “Beryllium” version of the Sequence Two - Monitor
The ScanSpeak Beryllium tweeter measures like a dream and it will be a great fun to work with it. Early listening tests indicate that it’s some special hard cone dome tweeter, one of the very best. :T
Another very interesting tweeter is the RAAL ribbon, which I will use in a 3-way reference setup together with AudioTechnology drivers. The AudioTechnology drivers are currently being built at the factory and I hope to get them by the end of the week. :B
Two different ScanSpeak designs are in the pipeline too, a small sized 2-way and a small sized 3-way. Hopefully I will find some time to write about other topics too.
So much fun to do and so little time……
Regards
/Göran
Regards
/Göran
