Seems threads without completion dates are all the rage... not that I have finished my existing speaker projects! Oops. But I need a replacement before I can take the Ansonicas out for finishing. A room without music! no way.
I'm finally going to be using the OW1's I won at DIYChicago a bunch of years ago! These have a nice flat response and extend fairly deep for a 3/4, not to mention keeping up reasonably well off-axis. Not the last word in distortion, but with a fairly "nice" sound, they introduce (a very very little) distortion the way we like to hear. So the system is being designed to build upon that.
Woofers will be a pair of Seas CA18RNX.
Bridging what little gap I find between these will be a Tang-Band W4-1320SJ (bamboo cone, truncated frame, neo magnet).
This will be a TMWW layout, probably vertical baffle for woofers and a kick back for the mid+tweet and large facets... a familiar look for many, but not without reason. I still have some modeling to do and may go for a full tilt.
Crossovers - I'm going to try something crazy, for me at any rate. There's tons of overlap on these drivers as far as usable frequency range, and even driver spacing. It's a very compact layout. So the goal is to push really low order slopes, which is where the experimenting comes in. Driver sensitivities are very evenly matched, responses pretty consistently flat through the usable ranges, no major problems anywhere... 1st order? Might happen. And I may actually work up a couple options to listen to.
Plans subject to change as I wait for the Seas drivers to become available (seems Meniscus has 'em, and a bit cheaper than Mad still, so we'll see...) and do a little more simulating on the box layout and the rest while I wait. Weather is getting to where I can start taking over the garage for a Saturday to make sawdust... and speakers.
I'll also soon have parts for yet another project... WWWWMTW 3.5-way, 180mm woofers but a sensitivity between 92dB and 94dB at 2.83v. Tuning around 30Hz, probably 28Hz. One thing at a time, and that one will take a while to build.
