I'm in the process of making statements as fronts and they will be accompanied by Jed's Line-Up F4's as surrounds.
My statements will have front ports with black tubes and I would like to match the F4's to them in look by outfitting them with similar tube ports instead of the original slot ports.
If I use a port that is 50mm (2 inches) ... which is quite close to the area of the original ports ... can I just assume the length should remain the same? Or are there more complex things to add to the equation?
If I let go of the slot port ... does that mean I should make the cabinets slightly smaller too to compensate?
Thanks for any suggestions.
