....road signs to get me where I want to go:
In my next project I'd like to make sure I get my vertical dispersion (especially above the speaker) as even as possible. Not necessarily perfect, but better than some of the commercial designs I've lived with. (Matrix 804 comes to mind as one that was particularly week in this dept.) I'm not one of those people that only listens to the stereo from the sweet spot. Actually, just the opposite: I'm rarely in the sweet spot. While I realize that horizontal dispersion is a higher priority, Im not interested in living with a'nother speaker that sounds so drastically different when standing up.
My experience has been that closely spaced drivers, whether mtm or tm helps. It's also been my observation that having the mid (if it's a single mid design) helps with vertical lobing issues above the speaker. I'm not sure if that's because of the type of crossover used with that example, or just a lucky coincidence.
In the case of an mtm, it's my understanding that running the crossover as low as possible also helps with this. I've also "heard" that steep crossovers can help with this as well. Correct me if I'm wrong, but mtm's actually have more lobing issues than an tm, but the issues are consistent from top to bottom, unlike a lot of traditional tm designs that have severe suckouts at the crossover above the tweeter axis.
Something I'm less clear on is the subject of crossovers in phase quadrature. I hear from some that they have a better power response that other crossovers, but I've also read that they exhibit greater peaks or nulls in the off axis than other crossovers: http://www.stereophile.com/content/s...inkwitz-page-4
I'm currently listening to an mtm with a crossover that's in phase quadrature. I'm about to put together 2 different crossovers that exhibit similar (nearly identical) on axis response but one will be in phase quad and the other will be in phase (at crossover). Curious to see how they sound different. I'm relatively pleased with how good the current version sounds off axis - both vertically and horizontally. C to C spacing of mids is about 9.5" and the crossover is (on the high side, I realize) at about 3.2kHz.
I know this goes against the grain of some of the powers that be, but I'm generally not a fan of complex crossovers. I'd rather work with well behaved drivers and keep the circuit simple. No, I'm not talking a cap and coil 2 way (thank goodness I've graduated beyond THAT particular phase), but the simpler the better, especially considering how expensive the xover parts I like to use are. :cry: The tweeter I'm committed to using won't crossover all that low (compared to some), so I'm stuck with going no lower than maybe 2.5kHz.
I'm torn between going with an mtw layout and an wmtmw. Some people say (and this has been - to a degree - my observation as well) that mtm's exhibit a vertically limited soundstage: like you're listening to the sound through a wide slit. Furthermore, that (all things being equal and assuming that distortion due to excursion is a non issue) an tm just sounds more "pure" than it's mtm counterpart.
Anyway...just trying to get some ideas and information to figure out which fork in the road to take. Thanks for taking the time to read through all this meandering.
Cheers!
Cheers!
