As if there aren't enough of these floating around here, I've got questions of my own. Although I had a couple threads on this topic circumstances have changed enough to warrant a new thread I believe.
Wants: 2 or 3 way speaker project (L/C/R matching or close) that can handle theater and music duties in my living room. Ability to handle high volumes a plus as we frequently have people over for movie nights and the occasional barbeque or late-night party (thank god for awesome neighbors that would rather join the complain!). Ability to handle low-end bass is not much of a concern, as long as I can get low enough to effect a smooth cross over to my subs at 60 or 80hz.
Physical constraints: The room is sub-optimal if you describe it generously. Speaker placement will have to be less than 12" from back to wall. Listening position is approx 12" away, and also next to a wall (room treatment suggestions welcome!). Center channel will have to be wall mounted or be placed on a fireplace mantle which has a depth of only 8.5" from wall to lip.
Budget constraints: Ideally I'd like to budget no more than $400/pair for the left and right. If truly compelling option is available for slightly more I can consider it. $500 is about the max I can handle to allow money for construction and finish.
WAF: Thin profile floor standing is probably the best option. The monster subs I built sound amazing, but....they may have to be sold and redesigned to be slightly more compact and less visually imposing.
Electronics: Currently running an Onkyo TX-SR605 receiver. It's not 4-ohm stable, but upgrades are in the works to move to a new Yamaha AVR and an Emotiva XPA amp.
Rear speakers are not a factor in this particular case. A sloping roof + an external wall means I'm probably looking at architectural drivers unfortunately.
Picture of said room:
Edit: pardon the mess in the picture.
2nd edit: Designs I have been considering are the Natalie Ps, "out- Khan-neatos", Sietecerocero, Lou C's Cryolite, Zaph's BAMTM, and CJD's RS150 MTM.
