This isn't normally a question that I ask as typically I'm the guy who is trying to talk friends out of using car audio equipment in a home theater setup. As it happens, I got a good deal on a pair of JL Audio 10w6v2 (dual 4 ohm VC) subwoofers that I briefly used in my car. It turned out that they just took up too much room and left so little trunkspace that I removed them and went significantly smaller, leaving me with a pair of subs I don't know what to do with.
The two options of course are to either sell them or keep them.
If I keep them, I would like to build a pair of small sealed boxes for use as stereo subwoofers in a music room. I imagine they would suffice just fine, but the problem comes with powering them. They can be wired for either a 2- or 8-ohm impedance and typically work best in the 400-500 watt range. Plate amps that can support a 400+ watts at 8 ohms are pricey. I used to run a Behringer EP2500 for a couple of Ascendant Audio 18s back in college, but that was an environment where volume was far more important than quality, and the fan was annoying even then. Plus I would need to get some form of crossover going, even though those on my preamp are moderately extensive. I wouldn't want to run anything like that on a decent stereo.
So I guess the question is, are there other options I'm not seeing? Would it be more cost effective to sell the subs for a few bills ($150 apiece at best, I imagine) and put that towards an equivalent system that can run at 4 ohms and thus use cheaper amps?
