I have a 3 way SEAS Prestige line speakers. They are H1208, H1141, and H1212. Built these as my first speakers back in 2008 and looking to rebuild them with better cabinets and get the tweeters at a more ideal height. I was considering expanding into a MTM arrangement with another H1141 mid range driver, and adding another H1208 to the low end for a WW MTM setup. I was wondering if this would be worth my while to even rebuild these or expand them to the WWMTM. I went into this project blind on the advice of a sales rep from MadiSound. I have attached the crossover and leap modeling used to make these speakers.
I am looking for feedback from experienced and more knowledgeable builders than myself on this design and if I should pursue it or just go in another direction. I do not want to sink more money into these if they are not that great of a design.
Also if I expand the number of drivers what modifications should I make to the crossover or should I start over with a whole new design.
I have the ability to build the cabinets and more than enough tools to get them done correctly.
Attached are the LEAP and Crossover
