Hello, I've been lurking here for a few months and just recently registered.
I've been reading the thread about using In-Khan-Neatos as all 7 speakers in a 7.1 setup. My room will be 17x24 and will be a semi budget build as far as the electronics go. I own a remodeling company with a cabinet shop and can get pretty elaborate with the construction part, but the equipment part is where I'm lacking. (probably the opposite of most of you...)
I'm attaching an overhead of my room layout. I'd rather not do an AT screen, and would want to place my center under the screen and the front sides and rear into columns built into the walls.
I'm looking for a good sounding system, not necessarily the end all/be all ultimate system that some of you have the ear to appreciate. (I don't have that ear and at some point the law of diminishing returns says a lot of really great stuff would be wasted on me.)
So, as a start, would 7 In-Khan-Neatos work in a room this size, and/or is there a better choice (center especially)
Also is there a good DIY sub I could build a pair of for this room?
I'll update as I go, but I'm sure it'll be a slow build.
(The Lshape in the pic has changed with the screen wall moving to the back of that space and the left side of the L becoming the equipment room.)
