Hi guys I am building a subwoofer enclosure for my vehicle. It will be installed in a Santa Fe trunk. The subwoofer is an Fi BL 12"
BL12
DUAL 1 | DUAL 2
Fs: 35.2 Hz | 39.8 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 4.68 | 4.72
Qes: .25 | .25
Qts: .24 | .24
Mms: 212g | 212g
Cms: 0.96mm/N | 0.96mm/N
Sd: 480cm^2 | 480cm^2
Vas: 31.2 l | 31.2 l
Spl: 89.1dB 1W/1m | 89.1dB 1W/1m
Bl: 16.6 N/A | 22.7 N/A
Xmax: 18mm | 18mm
Rms: 1000W * | 1500W *
Sealed box: N/A cuft | N/A cuft
Ported box: 1.5-2.5cuft | 1.5-2.5cuft
Sub OD: 12.500” | 12.500”
Cut ID: 11.125” | 11.125”
Mounting depth: 6.750” | 6.750”
Displacement: 0.18cuft | 0.18cuft
I am powering it with a Soundstream RUB1.1600 Mono Amp, 1600w RMS @ 1ohm.
Ok now what I am wondering is how should he WinISD graph look? Im not sure wha I should tune the Sub to but I would like it to hit low bu still cover a decent range. I was thinking 35hz in a 2.5 cubic ft box. But still when I look at the graph I really dont know what I am looking for or what it should like like. I hope I have provided enough info for someone to help me out. Thanks a lot guys.
BL12
DUAL 1 | DUAL 2
Qms: 4.68 | 4.72
Qes: .25 | .25
Qts: .24 | .24
Mms: 212g | 212g
Xmax: 18mm | 18mm
