Anybody have a 4Tse curved template? I"m horrible with sketchup, and am thinking of a winter project. Going to hcange my boxes to curved.
Curved 4Tse template?
A few members have made them but I feel that Deewan's are the best so far!!!!! Scroll down to Deewan's pics....enjoy!!- Bottom
I actually dream of curved dynamics lol I actually have all the parts sans wood etc. I am a bit skeptical because I have no wood working skills what so ever and I am really not interested in screwing up a project and be left with wood not fit for fire wood.
If you come up with some templates run your figures by Jed and he will let you know if your math is right and bless it with his stamp of approval.
Needless to say if you do come up with templates I would truly appreciate it if you were to share them.- Bottom
Something of interest.- Bottom
I saw that. That is pretty much the idea, but it's for the CC, so there is a size difference. I think the CC was about 1" smaller in depth and about 1" wider.
I was going to try and muck with the templates here and see if I can get the proper volume. Problem is figuring out how to calculate the volume for this shape.- Bottom
For what it's worth, Sketchup has a lot of limitations with curved surfaces and curves in general. It doesn't have the ability to "understand" a circle. It can only approximate them with polygons.
This isn't a problem when drawing up an idea, but it can be a real PITA when you want to generate g-code for a CNC.- Bottom
Yes I actually read all of those pages and came to the same conclusion that you did. I was working with someone but they had a death in the family and they told me they do not know if and when they will be able to help me build them.
I'm not sure if soldier7's clearwave speakers have the same dimensions apart from them difference in height. I went to the CLD site to look up his speakers but I can not find them.
The traslam would be an excellent way to go if it were not so pricey. Soldier 7 had his would cut via CNC and he is in $500 in materials for one speaker.
Now if you can cut the wood yourself and keep each piece to spec then you are golden.- Bottom
