Finishing Touches for a Flat Finish?
  • ratchetfps
    • Jun 2010
    • 37
    I'm driving towards the tail end of my mini statements project, and am hoping some experienced masters can help me get to the finish line.
    Right now I am trying to decide what final steps I should take to get a really nice flat finish. Here's what I've already done:
    - Coated cabs in wood glue/water solution to seal
    - Sanded with 80grit
    - Sanded with 320grit
    - Applied primer (Rustoleum Pro High Perf. Enamel Primer)
    - Wetsanded with 600grit
    - Applied color (Rustoleum Pro High Perf. Enamel Flat Black)
    - Westanded with 600grit
    Now I am left with a reasonable finish (in most places), but am still facing a bit of orange peal and a rough spot or two due to overspray from the front. Overall, it looks quite good and I think I would be happy by just wiping the entire thing down with some acetone, but I am wondering if there are some specific tips for flat finish. I have read countless threads about piano black finish and high gloss approaches and am wondering if any of these techniques should be used for a flat black finish.
    Things I am considering:
    - Wetsand with 2000grit followed by rubbing compound
    - Rubbing compound only
    Does anyone have any advice to obtain a dead flat finish? I am thinking about avoiding rubbing compound altogether because I fear it may cause some shine. What should I do to finish this up while keeping it nice and flat?
  • Wheels
    • 61
    When you say flat, do you mean perfectly smooth, or no reflection? If it were the latter I would say you could apply a flat sheen clearcoat on top of your paint. If its perfectly smooth, I don't know.
      If you're getting orange peel, it sounds like you're either spraying too heavy/slow or too thick (if it's not rattle-can, in which case you have no control over this) or both. To get it super silky smooth those last coats should be laid down quickly, and without adding much depth, with a 2000grit wet-sand between.
      I think...
      Been a while since I've sprayed and never gone for a flat finish, always gloss (with a spray) excepting the projection screen painting project I undertook.
      • David G
        • 170
        I found that a final coat of matt clear coat looks really nice and natural.
        • Wheels
          • 61
          I think...
          If it is a rattle can, you're just going to have to move faster. I just painted 2 cabinets with krylon flat black and had no orangle peel. granted it wasn't enamel, but CJD is right, too much paint per coat will create an orange peel texture
          • ratchetfps
            • Jun 2010
            • 37
            Appreciate the replies! When I say flat, I mean perfectly smooth with as little reflection as possible. A satin-like finish would be fine, so I'm leaning towards the rubbing compound. The only concern I have is that rubbing compound is traditionally part of a multistep process to achieve maximum shine (with buffing and waxing after). I suppose I'll have to do a test spot and see how it goes 8O
            • Wheels
              • 61
              If after you are done with the rubbing compound, get a clearcoat with a flat sheen and put it on top, very lightly, even over places you didn't have to sand it shiny. Mask off anywhere you don't want it so you don't get any overspray and as long as you keep it clean (and not too heavy) it should dry smooth.
              • Solid-State
                MDF sealant for Black Lacquer Finish
                by Solid-State
                I'm curious what lacquer based sanding sealer people are using these days to apply a black lacquer finish to MDF. I need to be able to source it in Canada as well. This info was taken from ShopBot forum from a very experienced MDF cabinet maker.
                "To get the best results, I suggest...
                28 April 2010, 15:57 Wednesday
              • jeff_free69
                Final touches on a black glossy finish ?
                by jeff_free69
                just about done with the finish on the cabs for my zaph SR-71.
                This is my first "neatness counts / from scratch" project. All my previous projects have been either utility cabs for pro-sound or refurbs of good quality hifi cabinets.
                i didn't intend to be such...
                09 January 2008, 15:47 Wednesday
              • Rolyasm
                Perf Screen Viewing Distance?
                by Rolyasm
                Hello again, just me...
                I am considering a perforated screen and my main viewing area will be about 12 feet from the 100-110 inch screen. Anyone familiar with perf screens know if at this distance I will see the perf holes? I am sure all screens are different, but does anyone have any personal...
                23 November 2005, 20:04 Wednesday
              • ratchetfps
                Dealing with driver cutouts when painting ?
                by ratchetfps
                I have finally finished my pair of mini statements but, regrettably, have done the unthinkable and hooked them up completely to test them out prior to painting! I did so due to the fact that winter was fast approaching and by the time I finished my build it was already starting to rain. Now that the...
                22 July 2011, 13:03 Friday
              • fjhuerta
                Is a perfectly flat frequency response always a good thing?
                by fjhuerta
                Hi all!
                After more than half a year of playing around with my Nat-P's, I finally found a network that made them perfectly flat. Gone are the peaks and valleys, and they are replaced by a perfectly flat on-axis response.
                But...
                I told my wife to give me her...
                21 January 2007, 22:21 Sunday
