Hi folks,
What sort of changes need to be made to the Modula MT crossover to use it in a three-way with the JBL LE14A woofer?
I don't expect perfection, but if someone could help me get into the ballpark, I would appreciate it. Even if it means using an L-Pad.
I've attached the only t/s #'s I could find for the JBL LE14A woofer. It will be in a 60L enclosure tuned to 30hz. The Module MT will sit on top of this unit.
Any help with the crossover would be appreciated.
I cannot afford an outboard processor & amp setup to run the LE14A's separately. So it needs to be a three-way crossover.
Here is the normal Modula MT crossover by Jon Marsh:
