First of all thanks to all of you who have documented their builds and research. It's been inspiring as to getting my hands dirty.
As I am currently without a sub for my HT system, I've decided to start there.
My enclosure is a stand made out of higher quality plywood, and before driver/bracing is approx 4.8 ft^3. It will be connected to a Yamaha rx-v667. So far this is my intended BOM:
I have insulation left over from insulating my garage to use for fill. As far as I've read this should be sufficient.
I haven't decided whether or not to box the amp internally or externally onto the back of the sub.
Please offer your input on any cost saving measures I may be overlooking. Or more likely, anything I have overlooked into including. Or of coarse the third option of easy upgrades.
Also I believe I am going to downfire this, what is the recommended ground clearance?
Dayton Audio BPT-38G Binding Post Pair w/Tab Part Number: 091-340
$8.26
Speaker Cabinet 1/2" Super Toe Spike Set 4 Pcs. Part Number: 240-730
$6.90
Cast Frame 1/4"-20 Speaker Mounting Kit Part Number: 260-778
Dayton Audio SW-25 Subwoofer Cable 25 ft.
Part Number: 181-644
$22.44
Speaker Gasketing Tape 1/8" x 1/2" x 50 ft. Roll Part Number: 260-542
$6.88
Bash 500W Digital Subwoofer Amplifier Part Number: 300-752
$238.58
Dayton Audio RSS390HF-4 15" Reference HF Subwoofer 4 Ohm Part Number: 295-468
$159.90
Subtotal: $446.55
$8.26
$6.90
$22.44
$6.88
$238.58
$159.90
Subtotal: $446.55
