Hey folks,
Any strong opinions about the BASH vs. Dayton 500W sub amps? I'm going to build my first sub with the Dayton Reference HF 12" driver using Zaph's archived design. The Bash is quite a bit cheaper so I'm leaning that way. Some of the reviews say that it's relatively flimsy and would flex with the pressure of the sub so I'm planning on isolating the amp from the actual enclosure.
Happy to entertain other options as well, but 500W seems to be the right number if you have others in that range.
Thanks!
Thanks!
