Pics of some cabinets and baffles I made for Troels Ellams. I think they turned out pretty sweet.
Troels Ellam
Thanks Blue.
The cabinet is Black Galaxy granite and the baffle is red granite, not sure of the name.
The cabinet is 3/4 granite as is the baffle, effectively making the baffle 1 1/2 thick. Going to put them on a scale, I am curious as to how much they weigh.Seas Idunn
ZA5.2
ZA5.3CC
SB Acoustics 12" sub
Statement Monitors
CLD M5B- Bottom
Holy crap. That's a lot of granite! You can move those by yourself?!?! :E- Bottom
Originally posted by UndefinitionHoly crap. That's a lot of granite! You can move those by yourself?!?! :E
I am going to weigh them tomorrow, I would be surprised if they weigh 100lbs. They are small towers.Seas Idunn
ZA5.2
ZA5.3CC
Statement Monitors
CLD M5B- Bottom
Originally posted by blue934how did you make those cuts/miters?
david
The real time is in the baffles, each baffle requires about 2hrs of CNC time plus all the programming.Seas Idunn
ZA5.2
ZA5.3CC
Statement Monitors
CLD M5B- Bottom
Those speakers are so NICE! I've been following your various granite builds...so cool.
I never thought about them tipping over. That could be really painful!!!Statements: "They usually kill the desire to build anything else."- Bottom
I'd think that once it topples over, it's never getting back up again.- Bottom
Thanks for the comments
Yep, it could be disastrous for any one unfortunate enough to be under them which is why I have a disclaimer stating that they must be mounted on a suitable base that provides more stability.
If it were to fall and land flat on carpet it would have a reasonable chance of surviving intact. If it hits unevenly on a hard surface it will at best crack but more likely break in several places.
All an educated guess, not sure I want to invest the time to build one and push it over, plus I would have a hard time recruiting a volunteer :ESeas Idunn
ZA5.2
ZA5.3CC
Statement Monitors
CLD M5B- Bottom
Originally posted by richnenI own a granite fabrication shop so I have a bridge saw and a CNC at my disposal. I cut the cabinet parts 1/8" oversize then miter them on the CNC.
The real time is in the baffles, each baffle requires about 2hrs of CNC time plus all the programming.- Bottom
Originally posted by kmibbWhere do you live? And what would you charge for a baffle for Jeff Bagby's Continuums in that same red stone? It's the same tweeter and an Aurum Cantus AC130F1 (5-1/2" woofer).
I am in North County, CA. Just north of San Diego.
After fabricating the Ellam's using 3/4" granite for the baffle I have reached the conclusion that the material is too thin. This has nothing to do with the density of the stone or its suitability from an acoustic view point, the problem lies with the stress put on the baffle during milling. There is so little material left between the driver hole and the side that it is prone to cracking during milling.
I have fabricated around 30 baffles and have broken at least 6 during milling. I broke 3 baffles fabricating the Minuets,broke one and cracked one(which I was able to repair) building the Ellam's.
Then there is the shipping... I had three break in transportation just recently because I did not pack them well enough. I had the good sense to have the replacements shipped by a service that packs and insures them.
With that in mind the cost of baffles may be more than you are expecting but if you PM me the dimensions I will work up a price for you. I have over sixty colors of granite in 1 1/4 but none of the red used in the Ellams.
RichardSeas Idunn
ZA5.2
ZA5.3CC
Statement Monitors
CLD M5B- Bottom
Originally posted by BearAwesome work as always, Richard! You're really cranking through the speaker building.
I am having a hard time stopping, I have run out of rooms to put speakers in!
I am toying with the idea of a translam using granite and marble :E , after seeing Bigbards Sharkfins I was hooked on the idea. Those are some great looking speakers. :TSeas Idunn
ZA5.2
ZA5.3CC
Statement Monitors
CLD M5B- Bottom
Yeah, I asked where you were because I wanted to avoid shipping. With baffles that are heavy and fragile, it just doesn't make sense.
The good news is I'm in Bakersfield so it's only about a 4 hour drive (one way.)
Richard- Bottom
For those wondering about Richard's work, it's simply amazing. He did three Minuet baffles for me, and the work is basically flawless. I've been nursing a back injury, so I haven't had a chance to mount them yet, but I have been drooling over the bare baffles even before putting them into service.Welcome to Rivendell, Mr. Anderson.- Bottom
Originally posted by BearThat would look awesome, and yet, the amount of waste in the process would make it even more expensive than a wood-based version. You wouldn't have to worry about humidity cracks or de-lamination, though.
I am looking forward to seeing the finished product when you are back on your feet.Seas Idunn
ZA5.2
ZA5.3CC
Statement Monitors
CLD M5B- Bottom
I am having a hard time stopping, I have run out of rooms to put speakers in!What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
Now with website. www.5een.co.uk Still under construction.- Bottom
Granite speakers
I am the proud owner of thee Ellam's. Some of you guys worry too much, I'll be sure not to open a day care so they don't fall over and squish anyone
Richard did a faboulous job fabricating these- Thank you man. Also had a chance to listen to Richard's 5B's and they sounded awesome even connected to 15 pound integrated amp. Especially liked the 6600 wonder if I can modify these and install them
Anyway, Thanks Richard These are the first speakers my wife actually likes!
(Enclosed pic is the original wood version next to granite)- Bottom
Originally posted by welly192I am the proud owner of thee Ellam's. Some of you guys worry too much, I'll be sure not to open a day care so they don't fall over and squish anyone
Call me when you have them working, I want to hear them next to the wood version.Seas Idunn
ZA5.2
ZA5.3CC
Statement Monitors
CLD M5B- Bottom
If you're interested in building Jeff Bagby's Continuums you should head over to Meniscus for the kit offer, or to Salk Sound if you want a finished built version.
You're not likely to get an answer with an unrelated questions (to the original topic) posted to these posts from 2011. They're probably no more likely to have built the Continuum than I am.the AudioWorx
Just ask Mr. Ohm....- Bottom
Thank you Jon!
I actually built them maybe 3 or 4 years ago, just curious what others are thinking comparing to the mini statements which my brother Asi built, and I love their sound more than others so far. I am looking for someone who may be interested in selling the minis, unfortunately I have no time right now...
I keep on saying minis, but I actually meant to say the monitor statements... the sound range on these monitors is outstanding, mids/highs are supper clean and "gentle", and the low end is incredible for 1 small woofer and a relatively small cabinet. The 4 Ohm Dayton has (maybe there are new ones now, this was few years back) one of the lowest frequency response.- Bottom
