New Eton 3" Ceramic/Mg Cone Midrange
Interesting- the impedance curve looks better than I would expect from the stated inductance- my first thought was that there might be inductivity modulation issues with distortion at higher frequencies.
Mounting and enclosure design will be tricky or critical due to the basket design. And sensitivity is on the low side (looks more like 85 dB than the stated 87 dB). I would expect a tonality similar to the TB mid used in the Statements.
Would be interesting in combination with a woofer system with a good top end in the 90 - 91 dB range (before baffle step comp). Would be interesting to see how well damped the upper end is, and what linear distortion behavior looks like up to 4 kHz or so.the AudioWorx
Just ask Mr. Ohm....- Bottom
Originally posted by JonMarshInteresting- the impedance curve looks better than I would expect from the stated inductance- my first thought was that there might be inductivity modulation issues with distortion at higher frequencies.Welcome to Rivendell, Mr. Anderson.- Bottom
I think Jed's right- the only reasonable explanation!the AudioWorx
If anyone wants to send me a pair-and I can probably get zaph to test it as well (er, maybe...) let me know. I've been a bit disappointed in the etons I've looked at, but that was quite some time ago and these look like some effort went into them.
mark- Bottom
Good news... I just got an email from my Eton contact and the data sheet is incorrect. The inductance is indeed .1mh. Eton said they will correct it at their website. Not sure if they've done that yet, but they will. They are also investigating larger diameter versions of this driver, but some logistics have held back that project to a later date.
Jed- Bottom
Originally posted by JedGood news... I just got an email from my Eton contact and the data sheet is incorrect. The inductance is indeed .1mh. Eton said they will correct it at their website. Not sure if they've done that yet, but they will. They are also investigating larger diameter versions of this driver, but some logistics have held back that project to a later date.
Jed- Bottom
