Hey all.
I'm getting close to building some speakers for my dedicated HT, have been lurking, and learning. I will be replacing my 20 year old hand me down Fishers (suck) and my ten year old Klipsch (don't snicker - the bill for two Klipsch ss-1s, and an sc-1and one KSW-12, a new Denon AVR2800 and a Sony DVD player in 2000 was $2,600 back then!).
Anyway, I was able to get three highly compressed particle board doors discarded from my work. They are meant to be sound "proof" conference room doors, are 9 feet tall, probably 38" wide and are 2" thick. All verticle sides are covered in really nice, real cherry veneer. Each door probably weighs 130 pounds.
So, do you think they would make good speaker cabinet material for the mains, center and sub? My surrounds will be built-ins similar to the Inkahn neatos and probably hidden inside columns in my dedicated theater (so not visible, no need for the cherry). I know I would have to chamfer the edges at 45* to keep the particle board core material from showing. But, since these are dense material used for sound proofing doors, I wonder it this would work and eliminate the need for internal bracing in the cabinets?
Thoughts?
These will go into my dedicated, yet budget oriented theater room. The room is approximately 12.5x17.5x7.5 with 1/2" drywall over 1/2" Celotec sound board.
Thanks for any ideas, or thoughts. If the opinions are that particle board is still the devil (even at 2" thick), then I'll use one door for a shop table and the others for shelving and go with MDF for the speaker cabs.
Here's how the chamfer would get the veneer showing:
Thoughts?
