Hi all,
This is my first post on this forum. attached is my current setup with B&W 683's as the mains and the HTM62 as the center(i apologize for the cable management, i realize it needs some work, as well as the power cable for the TV screen being way to short). i am planning to build a pair of Statements to replace the B&W's and as you can see there isn't a good place for the statement center. my original plan was to design a dual center based on the W4 and Neo 3.0 as used in the statements to flank the TV screen. then as i was going through the posts i found the R4 and R44 designs. and my question is; keeping the overall dimensions the same would it work if i changed the speaker placement from the front to the sides, as the shelf they are going to be placed on is only 7" deep. would this significantly affect the crossover design or over all sound quality of the speaker? my second question is which one R4 or the R44 would work best as a center channel, they will be powered by a B&K 200.5. any help or advice would be greatly appreciated. i was having issues uploading my pics as jpegs so printed them as pdf's and attached them.
-John
-John
