I am collecting the parts for a set of Statement Monitors. I would like to use them as monitors for my digital audio workstation.
They will be nearfield .. 2-3 feet from my head. Instead of the vertical alignment, I would like to cluster the drivers together .. tweeter on top of the mid, both next to the woofer. Basically the Center channel with one
woofer chopped off. I would build them in a mirror image pair.
They will be a foot or so from the back wall.
What would be the best crossover for this? The woofer will be the RS180-4, so the low section of the monitor makes sense. I notice some differences between the monitor and center mid and top sections .. what is the actual sonic difference? Which would be better to use in my application?
