I was going to purchase a speaker set then decided to do a diy setup. I was thinking of designing a 2 or 3 way system with crossovers etc but seemed a lot of work. then i came across single full range speaker setups in what they call bass reflex boxes. This is where my research has brought me too using full range speakers. right now i am just concerned with good mids and highs and will be getting a powered sub also. This is what i have and what i am thinking of doing.......First off i have an older aiwa receiver that outputs 175 watts rms 8 ohms per channel in stereo from 40h-20kh. What i am thinking of doing and would like your input here is using 4 hifonics full range 90h-10kh 8" square speakers rated at 200 watts rms 400 peak. using 2 per side L/R channel. these speakers are fairly new they just came on the market with being the first almost full range high output speaker for the car audio market. These speakers are 8 ohm a piece at 98.5 db sensitivity so i thought 2 in each side wired down from 16 ohm to 8 ohms would work wonderful. The question i have is will it work and what would the problems be if not? I understand that there is another 10k or so in the upper freqs that will be missing but will i really miss it? and when i wire these down for 8 ohm rating for my amp what happens with the wattage rating in each speaker? will each speaker set then handle more rms or less?
Q on full range speaker build.
Tags: None
I'm afraid you are on your own with these speakers. The web site for Hifonics has no specs for the drivers, so we could not even begin to guess what size box you would need or how to tune it. I doubt that anyone else that frequents this forum is familiar with them either. You might try one of the car audio forums and see if anyone there has experience with these drivers and has measured some specs for it.
Sorry,
Bob- Bottom
Thank you for the reply. I understand and have already emailed the company to see if i can get some kind of specs. I have already tried going through car audio forums and there is not much on these just a few people reviews that are very happy how loud these go that's it. from what i can gather October 2010 was roughly the release date on these so it hasn't been that long of a time. Hoping that i will get a response from them fairly soon and not weeks from now. Do you think these speakers look interesting or should i go towards a different direction?- Bottom
Also what i was thinking unless i am on the wrong page is the reason speakers sound the best in a round enclosure is because they put off circular sound pattern but these are square so thinking they would match a square/rectangle box better for sound. Not sure on this just makes sense to me that it might work that way.- Bottom
Two in each side? the whole point of those full range drivers is to be a point source. Also, they're often best in front/rear-loaded horn configuration as opposed to a standard bass reflex cabinet.
edit: Isn't that a car audio brand? I thought you were talking about a true full range driver...-Josh
That feeling when things are finally going right. Yeah, that one.- Bottom
Originally posted by numberoneoppaTwo in each side? the whole point of those full range drivers is to be a point source. Also, they're often best in front/rear-loaded horn configuration as opposed to a standard bass reflex cabinet.
edit: Isn't that a car audio brand? I thought you were talking about a true full range driver...- Bottom
Generally speaking it's best to avoid anything but round speakers if one is looking for the best sound quality. Reason being any shape other than round results in uneven pressure/stresses on cone from the suspension. This uneven pressure creates less than optimal (non-linear) cone motion
yeah I might be scratching this idea. just got excited when i seen the speaker and my head started going a mile a minute figuring out different possibility's i could do. I guess all it really is a loud mid bass speaker which looks to have a higher excursion than most or a decent guitar speaker really.- Bottom
Originally posted by obsidian231yeah I might be scratching this idea. just got excited when i seen the speaker and my head started going a mile a minute figuring out different possibility's i could do. I guess all it really is a loud mid bass speaker which looks to have a higher excursion than most or a decent guitar speaker really.-Josh
If you are set on a full range speaker, there is the new Parts Express Dayton PS220.
If this is your first DIY home audio effort, you will probably get the most happiness for your dollar and effort by picking a proven design. This forum is a great place to look (try the Mission Accomplished sub-forum). You are correct in that designing a 2 or 3-way crossover would be a lot of work, but just assembling an existing crossover is much more a sure thing (and still enough work that you can feel some accomplishment and pride in your creation). You'll blow anything you can purchase out of the water value wise (modulo a great deal on used gear) and you can leverage the design experience of someone who has created many many speakers.- Bottom
I'm thinking about doing a TL with said driver.^-Josh
