AviaTrix write up done!
  • Curt C
    • 791
    Just finished uploading it to my site.
    The write up covers all the AviaTrix variations so it is a bit lengthy, but hopefully I laid it out so it can be easily navigated.
    As always, I appreciate all your critique, comments and suggestions...
    Curt's Speaker Design Works
  • HeatMiser
    • 38
    Excellent writeup Curt.
    If you have the time, would you consider saying a few words about the process you used to determine if/how you would apply series capacitors to the woofers in the sealed version? Are there certain driver parameters that are critical in determining the suitability of such an arrangement, and can such a setup be modeled with some accuracy given the proper software tools?
    Thanks.
    Paul G
