Hi all.
I am at it again, this time a pair of Clearwaves Minuets. I chose these as I wanted to build a speaker using very high quality components, can use a PE cabinet and uses a baffle design that I can produce relatively cheaply out of granite.
I have a couple of options in mind on how to fasten the baffle to the cab. I am hoping that I will be able to install threaded anchors in the back side of the baffle that line up with the PE screw locations. If it is possible I will attach the baffle from the inside of the cabinet so there are no fasteners showing on the front.
Going to house the crossovers in the granite base of the stand with the binding posts on the back side of the base. I want a nice clean cable free look.
Still debating on which granite to use, was hoping to get some feedback on my choices.
I am leaning towards the black pearl or the tan brown.
All opinions are welcome
In order the granites are black galaxy, black pearl, tan brown and kilimanjaro.
