Zaph ZA5.2 Build
  • lcolbur1
    • Nov 2010
    • 134
    Zaph ZA5.2 Build
    Here's my Zaph ZA5.2 speaker build.
    MDF:
    Inside Front:
    Beveled Edge:
    Chamfered Edge:
    Glued:
    Inside:
    Flush:
    Flush:
    Primed:
    Painted:
    Crossover mounted and painted back:
    Inside with dampening:
    Inside with dampening foam:
    Fronts:
    Tweeter:
    Woofer:
    Mounted Drivers:
    Wired:
    Front:
    Flush Mounted:
    Finished Product:
    Sorry for the blur ops:
    Nice job, looks very good... :T
    • blue934
      • Mar 2008
      • 91
      I second Thomas, very nice! those ZA's are gorgeous drivers, aren't they?
      david
      • owdi
        • 62
        Nice. What is the white dampening material that you used?
        • lcolbur1
          • Nov 2010
          • 134
          Thanks guys.
          I used this stuff for dampening:
          2 layers for the top, bottom, and back. Just 1 layer for the sides.
          • 707kevin
            • Oct 2010
            • 52
            Nice! I FINALLY assembled mine today so I could listen. Paint can wait! hah
            Show off your speaker projects by posting the details and images of your creations. We encourage you to discuss with the speaker project designer his methods and results.
            • john trials
              • 449
              Good looking build.
              You should cut away the foam that is covering the resistors in the crossover. Resistors give off heat as current flows through them. More current (higher listening volume), more heat. Covering them up with insulation blocks the heat from dissipating. I recommend removing the foam all around the resistors and give them plenty of open space.
              • lcolbur1
                • Nov 2010
                • 134
                Thanks for the advice. I wasn't sure how much heat they generated, so I just covered everything, but I will definitely remove the foam.
