Acustic Foam
  • Silver1omo
    • Sep 2010
    • 430
    Acustic Foam
    Hi there, I'm looking to source locally (Mexico) some foam and found a place in Mexico City that specializes in acoustic projects and products www.comaudi.com.
    They carry eggcrate and triangular foam. The spec sheet says that it is polyurethane open cell foam with a density of 2 pounds per cubic feet.
    Does that sound right/appropriate for speaker building?
    which is better? Triangular? Eggcrate?
    They claim that the eggcrate has the following coefficients:
    250Hz 500Hz 1000Hz NRC *
    0.31 0.73 1.04 0.80
    Thanks in advance!
    Ivan.
    My Statement monitors
    Should be fine
    Doesn't matter
    • Silver1omo
      • Sep 2010
      • 430
      Thanks Thomas!
      Ivan.
