So I'm finally working on my next DIY project (not including rebuilding my OS), and it's Paul's Amigas. I'm building two pair at once - once for my friend and one for my uncle.
I've got about half of the MDF cut so far. I'm going to call some countering places to see if I can get some granite plinths made, too. Should be neat. One pair will be finished with Mahogany stained and with glossy poly. The other pair will have Walnut with a satin finish.
I have an important question for Paul:
It doesn't show on the diagram, but does the Amiga have the same internal shelf as the TRS-80?
And here's an important question for everybody. How is the best way to do driver cutouts when veneering? I was thinking of doing the small diameter hole for everything before veneering and then doing the counter-bore with a rabbeting bit after veneering. Is there a better way?
More pics to come, should get a bit of work done this week.
