Sub enclosure help
  • richnen
    • Jul 2010
    • 117
    Sub enclosure help
    Hi all.
    I am wanting to build a pair of subs using the L26Roy. I want each enclosure to measure 24" high 12.5" deep 12" wide. Should give me close to 40l.
    Will this shape rather than a cube cause me problems? I would prefer a sealed cab or using the L26PR.
    Any help would be appreciated, thanks.
    Seas Idunn
    ZA5.2
    ZA5.3CC
    SB Acoustics 12" sub
    Statement Monitors
    CLD M5B
  • 1Michael
    • 293
    Sub frequencies don't care what the shape of the box is, but cube shapes are the worst.
    Michael
    Chesapeake Va.
      No problem at all having a cube shaped sub.
      When possible it's better to have a sub with some depth behind the woofer so it has room to 'breathe'
      • 1Michael
        • 293
        I thought that having non parallel walls was the ideal for enclosures. Is that not correct?
        Michael
        Chesapeake Va.
