Just a Neo8 and Neo3. Crossover as shown. Measured response at about 1.5m. With the signal cut at 200Hz, however it is ARTA does that. The Neo8 is open back here as well.
Clearly, some issues to deal with. A nasty problem on the Neo3 at just about 10kHz, and a sad dip between 1k and 2k on the Neo8. I'm pretty sure I know what's causing the 10k issue, but this is a test rig and you can't have everything.
Yes, that is JUST a Neo8, and yes, it really does go that low. My usual solo unaccompanied violin was pushing the excursion limits, but that reaches to ~200Hz (196Hz if you must know).
I think I might be able to cross this to a 12" driver though, no? Maybe just a 10" though.
Or maybe a 15"
Or maybe a 15"
