They put a few things on sale over there and I couldn't hold out on a purchase, what cables do you guys recommend for these type of amps? They sell one cord on there site for $30.00 the balanced XLR cable is it worth it? Can someone drop a link for a better deal?
XPA-3 ordered, what cables should I buy?
They put a few things on sale over there and I couldn't hold out on a purchase, what cables do you guys recommend for these type of amps? They sell one cord on there site for $30.00 the balanced XLR cable is it worth it? Can someone drop a link for a better deal?Tags: None- Bottom
Originally posted by FaceI'd check out SignalCable.- Bottom
Originally posted by bigbardmusiqOh Lawd! there very expensive! ($139) this is what people are paying? I was wondering could this be like HDMI cables you can't tell a difference in the high price ones and the 3 dollar version.-Josh
That feeling when things are finally going right. Yeah, that one.- Bottom
Monoprice, Inc. (DBA. MonoPrice.com) specializes in the wholesale distribution of world class cable assemblies for home theater, PC, and high technology industries. MonoPrice.com offers a wide range of products from standard PC products, network cables, and HDMI cables to custom cable assemblies and wiring harnesses.- Bottom
Does your preamp support XLR outputs? If not build your own RCA's. It's fun and you can make it match your amp. That is what I did. I documented it here:
I built these because I was appalled at what high end cables cost. I am in the Navy and have built cables for the control and operation of nuclear reactors on both Submarines and Aircraft Carriers. This is far easier. Parts Express sold me all the parts. I just bought an UPA-7 amplifier from Emotiva so my cable color choices
I would use XLR's if I could though."You get what you Inspect, not what you Expect"
-Hyman G. Rickover- Bottom
I've been building my own XLR's for the last year and probably won't go back to pre-made cables. But, I wouldn't bother with XLR cables unless all components in the chain are fully balanced.
As for Monoprice interconnects, I tried them and thought they sounded awful. I would recommend cheapo patch cables from Radio Shack before those. Another good suggestion would be Mogami cables: http://www.mogamicables.com/SEOS 12/AE TD10M Front Stage in Progress- Bottom
I got Monoprice XLR's and put some techflex around them to make them pretty
Edit: BTW this was used with an XPA-3 direct from my dual mono DAC. I tried several cables and didn't hear any difference from the mono price cables, not to mention I took them apart to put the tech flex on and they are built very solid and the wire is a nice quality copper wire. Now maybe if you get into some ultra expensive cables you MIGHT hear a difference (placebo or not?) but as far as budget cables goes don't think you can go wrong with monoprice.- Bottom
I don't think so (Onkyo nr1008 ) http://www.us.onkyo.com/model.cfm?m=...s=Receiver&p=i I think I need RCA to XLR input. Help!!- Bottom
Originally posted by FaceAs for Monoprice interconnects, I tried them and thought they sounded awful. I would recommend cheapo patch cables from Radio Shack before those.- Bottom
I too build all my own cables with Canare. It's nice quality stuff and I can make everything to the lengths I need. But I would have no problem with the Monoprice stuff either.- Bottom
I've used monoprice, and they seemed just about okay to me. I liked bluejeancables, you might want to check there as well. Also signal cable - they are inexpensive compared to other boutique manufacturers, and seem to be just as good.
Sorry for being off topic here - I want to build a few interconnects (incld a long one for my subwoofer), and have decided on canare L-2T2S.What do you guys suggest for the RCA terminals?- Bottom
I like the Canare F series solder RCA types. Markertek has them I think. I've only ever used them with Canare Star Quad but they should be fine with the L-2T2S.- Bottom
I forgot to say that I ordered the XPA-3 on Friday too. I have my partially assembled actively crossed over system sitting here waiting for it. XLR cables seem very costly to me for what they are. I could see them being justified when you have a long cable run as professionals often do but not for me.- Bottom
If the components being used have fully balanced circuitry or you have long runs, it's worth using balanced cables. FYI, just because a piece of gear has balanced in addition to RCA connections, doesn't mean it has fully balanced circuitry.SEOS 12/AE TD10M Front Stage in Progress- Bottom
Having long runs and NOT having fully balanced cables won't really help you any... But long line-level cable runs is one place where it's really nice to have a setup with fully balanced signal.diVine Sound - my DIY speaker designs at diVine Audio- Bottom
