I have decided to downsize my center channel from the Dayton RS WMTW to the CJD MTM. My current center uses the RS28A tweeter and one RS150 so all I need to buy is another RS150 and some crossover parts. I found this post in the old CJD MTM thread. This is in reference to using the RS28A with an in/on wall crossover.
I understand where everything goes except on the tweeter...the last two items .05mH inductor/1.5 ohm resistor. Where do I put those?
Looking at the RS28A image off of CJD's website.
I'm not exactly sure...
Center channel will be going on wall or in wall below my TV.
How big is the TV?
It may be enough to simply bump down the gauge (bump up the impedance) of the inductors in the woofer circuit.
Well, I snuck a few minutes to toss some numbers together... swap values as you move across the posted circuit for the following:
Woofer:
.8mH 20ga inductor
40uF cap
.1mH inductor
6ohm/12uF zobel
Tweeter:
10uF cap
.33mH inductor
20uF cap
.05mH inductor/1.5ohm resistor
Woofer:
.8mH 20ga inductor
40uF cap
.1mH inductor
6ohm/12uF zobel
Tweeter:
10uF cap
.33mH inductor
20uF cap
