Calculating lowest room mode
  • sfdoddsy
    • Sep 2000
    • 496
    Today's task is to help me with remedial room acoustics 101. I think I understand how to calculate the lowest room mode for a rectangular room - multiply the longest dimension by 2, then divide the speed of sound by that.
    Does this still apply with a non rectangular room?
    Here, for example, is my current apartment:
    It is trapedzoidal, with concrete floors and brick outside (the diagonal) wall.
    In the main living area, the maximum dimension is the width, although that is broken up by an open kitchen I haven't drawn.
    Next longest is the diagonal wall.
    Or do I take the dimension straight down the hall to the front wall?
    TIA
    Steve
    Steve's DIY Dipoles
    Steve's OB Journey
    As I said over on the Mad board, why not just stick a sub in a corner and measure the modes with TrueRTA? Beats a buncha theory. :LOL:
    • Bruce
      • 156
      Steve,
      The only way your current calculation method will give good results is if you use it on the dimensions between only those walls that are parallel with each other. i.e. the 5.2m distance between the parallel 7.7m wall and the 4.4m wall, and the distance from the floor to the ceiling (if the ceiling is flat).
      Your diagonal wall will not produce accurate results between it and the 5.2m wall with your current formula.
      Yes, I also agree a PC software measurement system would be your best bet.
      Bruce
      ____________________________________________
      Bruce
