Driving one VC of a dual VC sub (DPL12)
  • sfdoddsy
    • Sep 2000
    • 496
    I've been reading and getting a little confused by some of the info at the Adire site. If I read it right, by driving just one voice coil on the sub, I will increase the Qes and thus the Qts, raising it to 0.8 or so. Does it double?
    And this increase in Qts would result in a peak in the response at around about Fs.
    Can anyone confirm this?
    Steve
    Steve's DIY Dipoles
    Steve's OB Journey
  • Jack Gilvey
    • Aug 2001
    • 510
    Theoretically, I believe so, although I've not tested it. That's how I run mine at the moment, although I've used various resistors to play with different Qes/Qts values.
    Not necessarily a peak (unless the in-room response was already flat), but I do get better low-end response, increased output/shallower rolloff approaching Fs. Linkwitz considers this method of counteracting dipole rolloff "crude" and much prefers active eq.
    Here are some further observations on RDO operation from Deon B in answer to my question:
    http://www.hometheaterforum.com/htforum/showthread.php?&postid=1582103#post1582103
    • sfdoddsy
      • Sep 2000
      • 496
      Thanks Jack.
      Would I also be correct in assuming that to short the unused voice coil I simply run a wire from positive to negative, and that running like this doesn't affect the Qts?
      Cheers
      Steve
      Steve's DIY Dipoles
      Steve's OB Journey
        • 15282
        Shorting the unused VC would probably not be a desirable thing to do. It would be akin to shorting unused windings on a transformer, and expecting the other windings to be unaffected. The shorted winding will act as an electromagnetic brake on the driver, EVEN when it is being driven. It will also act like shorted widing on a transformer, and as frequency and drive increase, the effective coupling (and shorting/shunting) will increase also.
        You can do a real simple experiment to investigate the effect of playing with the load on one VC, in either dipole or sealed box, by tapping the woofer cone (say, in the center of dustcap) lightly, with the VC open, then doing the same thing with it shorted.
        The problem with adjusting the "Q" by not using one VC is that you throw away power handling and sensitivity higher in the frequency range, and still need the same net power for a given output lower down- you've just changed the "natrual response" of the system.
        Now, in my other thread, I advocated selection of drivers for a closed box system to optimize the alignment, preferrably to one which could achieve desired results without EQ in this particular system I'm working on. But there were no VC's left unconnected or speakers damaged in this scnenario... :W
        In the case of a dipole system, I think I can see a little more justification for this approach, as electrical power handling is rarely the limit, while cone excursion (which isn't limited by number of VC's) generally is.
        So, while in some regards I agree with Sigfried on this one, I can also offer (for dipole use) a dissenting opinion. But then, I'm the bozo working on an all passive crossover dipole system, so what the heck do I know? :??
        I do know that I don't like scads of opamps in my signal path any more than Charles Hansen does... (well, OK, maybe I'll tolerate one or two carefully selected ones, but not if I can avoid it- I've even designed a non loop feedback LF equalizer to work in this system when it's finished, single ended and balanced inputs and outputs.)
        • sfdoddsy
          • Sep 2000
          • 496
          Thanks again for your erudtion Jon. I wasn't thinking of it for my dipoles, but for my sealed 142L monopole sub, the thought being that the change in Qts would act a bit like a Linkwitz transform.
          Checking Unibox, I would get an F3 at 18Hz, which seemed pretty good.
          Steve
          Steve's DIY Dipoles
          Steve's OB Journey
            • 15282
            And an F3 at 18 Hz is pretty reasonable, and in that large a box, electrical power handling isn't an issue- you'll be excursion limited at relatively modest powers. Can you say, "IB equivalent"? :W But where do you find the room to have several of them? That's why I was sort of interested in a dual DPL12 design for each side of my line array- with optimum positioning in room, can pick up six dB from back and side wall, and tune for fairly flat to 22 with very slow roll below that.
            But shorting a voice coil would work directly against that; it would be like having an amplifier connected to cone voice coil with no signal. You don't want low impedance sources opposing each other...
            • sfdoddsy
              • Sep 2000
              • 496
              It's just an LFE sub, and for rear and center bass. The mains are run full range.
              Steve
              Steve's DIY Dipoles
              Steve's OB Journey
              • Jack Gilvey
                • Aug 2001
                • 510
                Another option is to leave both voice coils unwired. That results in the ultra-tight, stops-before-it-starts bass so beloved of many an "audiophile".
                • Brandon B
                  • Jun 2001
                  • 2193
                  I thought the best way to do that was to wire the VCs out of phase? In case of stray wind currents in the room trying to move the driver.
                  BB
                    • 15282
                    Yeah, Brandon, I think you've figured out that one; then also, if someone by mistake powers up the LFE amp, it remain locked solid... :W
                    just the ticket for totally musical bass, especially if you enjoy the sweet sounds of silence...
                    ~Jon
                    • sfdoddsy
                      • Sep 2000
                      • 496
                      So if I reverse the phase on the subs and then turn them to face the other way, will the music stop before it starts?
                      I'm really getting the hang of this wiring stuff.
                      Steve
                      Steve's DIY Dipoles
                      Steve's OB Journey
                      • sfdoddsy
                        • Sep 2000
                        • 496
                        Jon (or others),
                        Getting back to dipole operation, would I be correct in thinking that even if one raised the Q of the driver, and hence had a shallower roll-off requiring less active EQ, that the overall volume capabilities of the driver are not going to improve?
                        In other words, there is a finite volume limit for a given driver that combination of fiddling with the ratio of Qts and EQ is not going to change?
                        Cheers
                        Steve
                        Steve's DIY Dipoles
                        Steve's OB Journey
                          • 1345
                          Yeah, baby!
                            • 15282
                            Steve,
                            Yeah, though the Q, roll off slope, and senstivity will change, the basic mechanical properties don't, so volume capability, based on Sd X Xmax, remains the same. Whether for dipole or monopole, for the DPL12, this is the ultimate limitation below 30Hz. Still, I think the DPL12 is a very nicely balanced driver design, especially for the DIY person that doesn't want to get into too much external EQ and whatnot.
                            Hi Hank,
                            Well, the beauty of my silly little balanced differenital gain cell, is that whether you want single ended inputs or outputs, or balanced, the whole circuit is there, working as a unified system (necessary for distortion reduction and basic operation), so one get's the goodies basically for free... The Ayre power amps and preamps are the same way- one fundamental balanced differential amplifier with differential (balanced) outputs. You just hook up what you need, and EQ is done by a RC networks in the transconductance stage, which tailor the output load impedance versus frequency, instead of using just fixed resistors, which would give you a flat, fixed frequency gain. For LF EQ, it's very simple, unless you wanted some peaking high Q gain, and if one does, then there's probably something a bit odd about the LF system anyway...
                            The whole idea is to do minimum damage to the music signal. If ONLY LF was running through it, no problemo- opamps would be fine. But since this is an "EQ Box" for what will otherwise be a full range, passive crossover (contrarian that I am), then I get more concerned. Unfortuanately, this "simple" circuit, once you've put in all the regulation and support to ensure it works open loop really, really cleanly, does have a lot of support stuff, and takes up a moderate size PCB- here'a a scan of the bare PCB, prior to assembly...
                            Yes, we do make more than CAD drawings at "Casa de Juan"; now and then we actually build hardware- this is the same module used in my homemade DAC's, going into a 2nd generation of construction.
                            But as Infineon's director of smart power development in Munich, Dr. Jeno Tihanji says, (and frequently), "Slow work takes time". Sure wish I had one of those sweet retirement deals Siemens was handing out to a lot of folks in their 50's back in the late 80's, early 90's; I coudl get a lot more USEFUL stuff done!
                            ~Jon
