Biscuit Joiner?
    • 8938
    Biscuit Joiner?
    Hi gang. I'm looking for recommendations on a biscuit joiner. Thoughts? Opinions?
    David - HTGuide flunky
    Our "Theater"
    Our DVDs on DVD Tracker
    • 1345
    David, I don't own one, so can't make a recommendation. I'm curious - why do you want one? Since biscuits don't increase joint strength greatly, most people (including Norm of New Yankee Workshop) say they use one to help keep two boards "lined up" while the glue-up is being done. I'm not sure that's a great advantage, unless with very large boards/panels. I've used biscuits (slot cutting bit on my table-mounted router) and they helped only on long boards I was edge-gluing.
    Anyway, I think I'd take a look at Freud's unit if I were in the market. Freud seems to be good value - I've got their big router.
      • 15269
      Hi Guys,
      Well, unlike Hank, the last thing I'd ever describe myself as is a woodworking expert. Maybe because of that, I have found biscuit joiners, or plate joiners, as they're sometimes referred to, to be fairly handy. Some folks say a biscuit joint isn't any stronger, other's say it is- I don't have an answer for that one, I just know it's easier for me to put together complex cabinets accurately with judicious use of a biscuit joiner. :W
      .... and yes, I did use biscuits extensively i putting together these, it would have been a lot harder to do it as accurately with the clamp and jig selection I have, otherwise.
      Here's a decent write up comparing the mertis of severl models on the market, including the Freud, DeWalt, Makita, Virutez, and Porter Cable.
      Woodsmith Plans has hundreds of the best DIY project plans from Woodsmith, ShopNotes, and Workbench magazines...all for immediate download.
      When I was selecting mine, I went in stores and hefted and played with the adjustments, and tried to get a feel for how they'd work in the actual application, to get an idea of how the adjustments and ergonomics worked. About as close as you can come to actually using them, without doing so. On that basis, I selected the DeWalt kit. :T
      You can find a fairly attractive price on the DeWalt at your local Lowe's; for local retail, the store help doesn't know beans from shinola in most cases, but their tool prices are good; I've also bought a Hitachi M12V router from them, at a price as low as the best I could find online. That's a honey of a router, BTW. :banana: I'm a sucker for nice tools....
      Good luck with your tool hunting.
        • 3791
        I love biscuits. Back in the day we used dowels and home-made splines but biscuits are much easier. Some glue joints, such as end grain on solid wood and edge grain on plywood, are quite weak without some help. I first used them to replace the dowels in hardwood face frames; now I use them for almost everything cuz they're so dang easy. Hank, just go buy one. You'll never look back.
        • PMazz
          • May 2001
          • 861
          We use them in the shop quite a bit. Alignment is the key. But be careful with the amount of glue you use with them. They work by swelling with the moisture from the glue. On solid wood, no problem. With ply or especially MDF, they can split the board if too much glue is absorbed. You can also run into trouble with bisquits swelling and then flat sanding, only to have bisquit shaped dimples show up later on because the moisture in the board and bisquit has returned to normal. Get one of the cheap plastic flat tipped glue bottles made for applying glue in the slot and use it sparingly.
          They will also create two small voids on either side of the bisquit when glued up, as the bisquit needs to be loose in the slot. Probably not a problem, but everyone always says to buy void-free material for speakers.
          A nail gun and glue is much quicker, unless profiling the edges is in the plans.
          Pete
          Birth of a Media Center
            • 27461
            I was gonna say bacon and egg or sausage and egg as a bisquit "joiner". Two bisquits jioned by your condement of choice. :LOL:
            Lex
            Cable Guy DVD Collection
              • 15269
              Well, you've got to watch out for swelling when sausage and egg are used too often as a joiner material with biscuits, too! :rofl:
              Pete, I found one good way to avoid the glue swelling problem with biscuits- it can be a real bummer with MDF and ply... use epoxy! It's stronger, too, especially if there are any voids! :B And it's safe to avoid the void, 'cause the biscuit won't get fat! Nor will you!
              • PMazz
                • May 2001
                • 861
                Epoxy for assembly.....Yo, Jon, I pay guys by the hour. And it's expensive! You DIY guys are nuts!
                Speaking of nuts....You should see the looks I get when I'm in the shop working on speakers. Not to mention the verbal abuse. They just don't understand the nuances of building speakers.
                Pete
                  • 15269
                  Pete
                  I can readily believe it, Pete.
                  I participate in a couple of woodworking forums from time to time, and though the guys are affable and tolerate me pretty well, I'm sure they fundamentally believe I'm looney tunes! Pune intended....
                  When they see something like the M8ta project, they just figure it's because I haven't learned how to do good right angles yet... :rofl:
                  I'm careful about how and where I buy slow setting epoxy, to get good deals. If you're just in need for a small quantity for a little job, Walmart has the best prices for the dual tube plunger thingies; they're about 40% less than your local big box store.
                  Also, a few different people have done studies on this, and concluded that "hard glues" like expoxies provide better damping and sound better in speaker cabinets... so does hardwood bracing like red oak, which has about three times the Young's modulus of MDF. That's why there's so much in the M8 two way.
                  But that's the beauty of DIY; since you're doing it for results for yourself, on a small scale, and your time and efforts are a big factor in the results, spending a little more on glue doesn't really affect the "profit margin" in anything except a more positive result for your efforts. Just MVHO.
                  ~Jon
                  • Brandon B
                    • Jun 2001
                    • 2193
                    My .02 :
                    The DeWalt and Port&Cable are probably the best feature/performance wise witht he P&C being tops but the DeWalt being a decent savings over it in price.
                    There are some nicer ones, but they are the pricey european models.
                    Any of the big brands will be a decent tool though. Also, I'm going off 2 year old research. Don't know what models have changed or come out since then.
                    BB
                      • 1345
                      "No pune intended"
                      Is a pune a pun with music?
                      Take it from Pete the professional: a brad nailer and glue is the way if you're building a cabinet too large for you to hold panels in alignment by yourself. Once the tool is paid for, brads are cheaper than biscuits and brad nailers are cheaper than biscuit joiners. Much faster than cutting biscuit slots and gluing in biscuits. More effecient and cheaper - what else do you want - green stamps? :LOL:
                        • 15269
                        Hey Hank,
                        I remember Green stamps.... guess that dates me a bit.
                        We aren't getting "pune itive" here, are we? :W
                        I've tried the brad nailer thing working at Tom's before, he has an air and an electric one, but I had trouble with splitting MDF edges. First experience with biscuits was so-so, second was an absolute breeze and charm. Never looked back since, it's just become SOP. I like the way biscuits keep everything lined up as I'm assembling, had more difficulty doing that with brads. Just a limitation of my work style, I guess.
                        Bottom line, I figure do what works for you, whatever it is.
                        Unfortunately, the last two weekends I'm mostly been doing work, not fun stuff. Knocked off about quarter till ten last night. My daughter was working late yesterday, too, so we just decided to put off Fathers Day till later this week.
                          • 3791
                          Well, this professional begs to differ with such a blanket statement. Naturally, YMMV. :LOL:
                            • 1345
                            Can't let that go, Dennis. Forums are chock full of blanket statements, including those by biscuit joint lovers The blanket statements I can't stand are the ones made by people comparing two items who have used only one of the items. As Jon alluded to, it's whatever method works for and is comfortable for you.
                              • 8938
                              Thanks for the replies gang, blankets and all. :B I already have a nice Bostich finishing nail gun, and am looking for something a bit less "impacting" for delicate joins.
                              Our "Theater"
                                • 3791
                                I just realized I didn't answer the original question. I like my Makita biscuit joiner a lot. The DeWalt looks nice as well but I haven't used one.
                                Of course, I also love my Senco air tools. I have several for driving different sizes and shapes of metal fasteners. Back in the day, Senco was clearly better than the others but that has probably changed. I've just never had any reason to look very hard at the other brands.
                                TOOLS INSPIRED BY HARD WORK, AND DESIGNEDTO MAKE IT EASIER.
                                • PMazz
                                  • May 2001
                                  • 861
                                  Oops....Same here.
                                  I use both a Virutex and a Lamello. Both work fine. Only thing I would say to look closely at would be the fence. The Virutex can sometimes be set out of parallel with the cutter if you're not careful. The Lamello is more precise, and can also be set to any angle, instead of just 90 and 45 degree.
                                  BTW, I was strictly talking about speaker enclosures. Plate joiners are indispensible for doing blind fastening w/o mechanical fasteners. As Dennis said, much quicker than dowels or splines. And more forgiving.
                                  Pete
                                    • 27461
                                    Have you tried New Balance with sorbethane? :LOL:
                                    Lex
                                      • 8938
                                      No, no, no. Not delicate "joints". JOINS. :B Actually, my running shoes are NewBalance - the 1006s.
                                      Boy, did we just go off topic, or what?
                                      Our "Theater"
                                      • AndrewM
                                        • Oct 2000
                                        • 446
                                        Well I'm a little late to the party, but my most recent project I finally bit the bullet and bought a biscuit joiner, just the cheapest thing I could find at Home Depot, and it made a world of difference in putting everything together. Granted it's not the best model out there, and took quite a bit of tweaking before it was all setup perfectly, but what a difference in assembling an enclosure. I went from having to use quite a bit of bondo and sanding to fade out uneven edges to just needing to sand them down a little bit and fill in the crach just a little.
                                        Well worth it.
                                        Andrew
                                          • 15269
                                          My experience exactly, Andrew. Experienced high volume woodworkers like Hank may have their skills with a nail gun honed to the point that that really works well for them, and allows them to work quite quickly. I do semi-serious woodworking on an occasional basis, so having tools that promote accuracy and polish in the finished results make a big difference.
                                          I looked closely at the Ryobi biscuit joiner for cost reasons, but the desire for ease and accuracy of setup led me to pop the extra bucks for the DeWalt; between it and the Porter Cable, though, I couldn't really see any significant advantages, and depending on working style, I could see some disadvantages. So I'm quite happy with the results.
                                          This is coming from a guy that does DIY wood working on an "On and Off basis since the early 70's. In theI built two sets of AR LST clones, (plus a number of TL designs, some dual 12" subwoofers, and in the late 70's got pretty serious with a friend on some TP speakers with complex cabinets). and with the radial arm saw and dado head which I had at the time, that was something of an accomplishment.
                                          As you folks well know, I'm more of a wire and sparks and PCB's kind of guy- my investment in CAD tools and test equipment makes my wood tool purchases look like snack food in comparison. :W
