A friend asked me to help him design enclosures for some HT speakers he plans to build (something I've never tried before ). He's chosen his drivers, and I thought this would be a good opportunity to see how this works in LspCAD. So I tried to follow the tutorial. I picked the BR template, add the source and ground, switched to 'simulate', entered the T/S parameters, used the wizard to get some values for box volume and port length / diameter. The calculated response looks reasonable.
Now comes the part I'm stuck at. Let's say I want to shoot for something like a B2 @ 80Hz, to work with a regular HT receiver. So I put that in as the target, check all the boxes I can find for the optimizer, start the optimizer, and... nothing happens. The optimizer just sits there. I see the box volume and port length bolded, so they should be set up right. Does the LspCAD optimizer not work with enclosures? I can play around with values by hand, of course, but at that point I might as well use something like Unibox.
So maybe that's what I should do, or am I missing something and LspCAD should be able to do this?
