Oppinion about subwoofer
  • vfrjim
    • Apr 2003
    • 36
    I have two of these (RFA-124's) http://www.rockfordfosgate.com/libra...124_128-ts.pdfhanging around and would like to hear some comments if these would make a good sub and in your oppinion, do you think that it would have a good "low end" punch. Also, what amp would you use to drive them and what type of enclosure would work well? ANY and ALL oppinions are appreciated, the key thing is that they are free to me since I have had them hanging around anyways and I do not need a crossover, my pre/pro and bass management unit takes care of that for me, I would just need a amp.
    Hard to say, in general car audio woofers aren't all that impressive for home use
    It's interesting that they fail to provide the Xmax, which is a fairly important parameter
      Xmax is listed as 9.3mm so two of them should move some air although nowhere near what good "home" drivers will move. With a Vas of 260 liters, they are going to need really big enclosures though. Whether they are worth the work of building enclosures for them, and the space they take up in the room, is up to you. Personally, if I were going to all that work, I'd want to use drivers that move more air. But, if money is really tight, you could put them in some big sonotubes and have decent sound pretty cheap as long as you don't turn them up too loud.
        Plugging the numbers into ISD online, I get an "optimum" vented enclosure of 131 liters (about 5 cubic feet) tuned to 22 Hz with a 4" diameter port about 11.75" long. So they aren't so terribly big after all.
        If you don't have any design software, ISD online is a quick and easy way to experiment with different box tunings.
        • vfrjim
          • Apr 2003
          • 36
          As you can tell by the subs, I use to be into car audio and these subs were not a typical "boomer" sub, they were used for strong, clean bass. So, would a vented type enclosure be recommended or would others such as a "bandpass" or I remember other type of enclosures that use to be popular in a push-pull configuration. Anybody have links on the pros and cons of different types of enclosures?
