Nice First DIY Project M8s? Vifa xT tweet?
  • myn
    • May 2003
    • 35
    I'm in the need of decent front speakers and I have been exploring the DIY market.
    I was convinced on the audioreview DIY project that costs around $200 all in for the parts + enclosure but a friend told me to check out this forum first.
    I've been reading several posts that reference the M8a midbass drivers and Vifa XT ring tweets.
    I've also heard people mention "M8" boxes?
    I'm basically looking for something as good if not better then the AudioReview DIY project.
    The project must contain prefab or prebuilt enclosures since I lack the tools and carpentry skills. Also a guide to how to assemble the crossovers associated to the project is a must too.
    Does anyone have any insight or ideas?
    Thanks for your help.
    -Derek
    • 15296
    Hello Derek, and welcome to HT Guide!
    The references you've heard are to an 8" two way system which I designed, and which a few friends and acquaintances have built. Actually, there have been 4 different versions of this, the last using the HiVi M8a woofers, and the Vifa XT tweeters. All shared a starting point using a modified Woodstyle enclosure.
    One of the shorter threads discussing this project is here:
    Unfortunately, they won't fit within your cost targets of $200 total for materials, as the aluminum/magnesium woofers alone are close to $200 a pair.
    Within the cost targets you're considering, take a look at the Nebular project showcased at Parts Express; it also uses the Vifa XT25 tweeter, and features straightforward plans on the PE site.
    Not having carpentry skills or tools is going to place you at a disadvantage cost wise, though. PE does have some very nice finished cabinets, but a pair in the right size range for this system is also pushing $170 alone.
    But the fit and finish and ease of assembly and modification are first rate- I'm just finishing up a pair for my daughter, using the Vifa tweeter and a HiVi D6 woofer.
