Phase Correction - I have the power, should I use it?
  • sfdoddsy
    • Sep 2000
    • 496
    I have the frequency response of my dipoles down very flat in room. So, since I have no life, I thought I might take a look at the mysterious world of phase.
    One of the nifty features of my new dbx Driverack 260 is that it allows one to specify delays for all drivers individually, and also adjust the phase for all the drivers individually.
    Do the poobahs think this is worthwhile?
    And if so, what is the best way to find out exactly what phase issues I may have. I have ETF, TrueRTA and the demo version of SpectraLab to play with.
    This swine awaits your pearls.
    Steve
    Steve's DIY Dipoles
    Steve's OB Journey
    • 15213
    Phase and amplitude response are inextricably linked. Now, if you've got your system dialed in for "flat" response, then you've taken care of the phase response in the crossover region already. Adding delay to specific outputs should only mess things up at this point.
    OTOH, it's not likely that you have zero phase errors, just that the phase errors are the normal ones associated with the crossover filters.
    If you want to explore that, and get a little depressed, get a pulse generator and a scope, and try passing a 10 millisecond or 1 millisecond pulse waveform.
    Then, sit back, relax, have a margarita or a good beer, and be thankful we don't seem to hear the way that test instruments can, or the way that most advocates of TP speakers claim we can.
    BTW, been there, done that, wrote the book, optioned the movie, re TP speakers which will pass a good 1 millsecond or 10 millisecond pulse on axis... in the seventies.
    I personally think that if every thing else is similar (axial response, off axis power response, room interaction, etc., most folks will only hear a subtle difference between a good TP speaker and an equally good, but non TP speaker.
    If you do want TP, forget mult-way dynamic speakers, DSP, etc; stay with the dipole thing, though, and get a pair of these:
    Combine it with a dipole sub array, could be pretty dang awesome....
    If I didn't like building stuff so much, they're what I'd own.
    Best regards,
      • 3791
      Steve, correct me if I'm wrong but I think you were asking a more basic question than the TP stuff Jon dove into. Assuming you followed SL's lead and tailored the response of the drivers for an LR4 acoustic rolloff at the crossovers, it's easy to optimize the driver delays. Just reverse the wire on the mid (or reverse the mid polarity in the DSP) and look at how deep the notches are at the crossover points. Fiddle with the delays to get the notches as deep as possible.
      • sfdoddsy
        • Sep 2000
        • 496
        Well, I guess I'll just have to listen to music then.
        What an interesting concept.
        Steve's DIY Dipoles
        Steve's OB Journey
        • Davey
          • Jan 2003
          • 355
          Steve,
          Check the Behringer DCX2496 setup file that I sent you a few weeks back. It's programmed with driver delays that should be about right for your system.
          Cheers,
          Davey.
          • sfdoddsy
            • Sep 2000
            • 496
            Thanks again Davey. The delays suggested between mids and tweeter were about what I had, but the bass to the others is a bit longer. I did mine from the middle of the H-baffle figuring that to be the acoustic center with front and rear facing drivers, did you do yours from the rear driver?
            Steve
            Steve's DIY Dipoles
            Steve's OB Journey
              • 27461
              Interesting concept? It's every DIYer's worst nightmare! :LOL:
              Lex
              Cable Guy DVD Collection
                • 3791
                Speaking of Soundlab stats, there's an 8 year old pair of A1s on Audiogon for $4K. :E :E :E :E
                Must resist, must resist, must resist........
                PS, Jon, they're located just north of you. "Honey, why don't we drive up to Santa Rosa for some sightseeing?" :rf
