Best internal wire for a woof?
  • Brandon B
    • Jun 2001
    • 2193
    Some sealed woofers (lambda SB10's) for use on my 2ch music, what's good reasonable wire for inside the cabinet. Decent quality 10ga sound king type stuff good enough since it's 250 Hz and down, or is there a much better choice for under $5 a foot? (since I only need about 6 feet).
    BB
    • 27461
    how about 22 AWG solid silver in teflon? Can't get much better than that. Let me know if that interests you, as I have some on hand here...
    10 gauge is overkill really. I'll take quality over quantity any day.
    Lex
    Cable Guy DVD Collection
      • 10934
      Saw an interesting cut-away of the insides of a JM Lab monitor. They were using wire that must have been 6-8 gauge for all the drivers including the tweeter.
      Unfortunately I can't find the link to the pic.
      • Brandon B
        • Jun 2001
        • 2193
        Lex
        These things are running off a Crown MA2402, and so will be taking peaks of 800 watts or so. While I agree about Q over Q, isn't 22 gauge a little light for this?
        Now for the 2 ways they will be mated to, I would consider the silver stuff.
        BB
        • Brandon B
          • Jun 2001
          • 2193
          Boy I'd be nervous trying to solder 8 gauge wire to an expensive tweeter. Oops - overheat.
          BB
            • 15214
            I have some custom Litz wire I had made up in the mid ninetites (for things like Class D amplifier inductors); it's 12 gauge, 360 strands. That's a bit over the top for LF, though!
            Below 250 Hz, with the runs you're talking about, conventional stranded copper is OK, IF the insulation won't corrode the copper surface over time; unfortunately, a lot of the zip cord style products have issues in that regard. I personally prefer fully insulated individual strands, but then everyone knows I'm a nutcase. The "cheap" wire I use for speakers internally is silver plated teflon insulated stranded wire, usually AWG14. I wire my "nicer" speakers internally with Cardas 11.5 AWG (which uses golden ratio stranding, and is especially neutral in the midrange), or with my custom Litz. The Cardas 11.5 is about $3 per foot- single strand, so it may not fit within your cost constraints. For tweeter circuits, the 15.5 AWG Cardas works well, and is only 1.70 per foot. Avalon uses Cardas for internal wiring.
            Best regards,
              • 27461
              I also have 12 and 14 gauge silver coated copper in teflon. and 22 AWG copper in teflon, that could be braided and use all 3 strands for a much higher aggregate gauge. Whatever, let these guys fix you up here is fine by me.
              Lex
              • Brandon B
                • Jun 2001
                • 2193
                That sounds about the speed I'm looking for. What's price and shipping (regular ground) on the 12 and 14 gauge stuff, for 25'?
                BB
