Any Suggestions On My Next Build
  • mgrabow
    • Dec 2009
    • 30
    I am finishing up design changes to my next build and figured I would put it out there if there were any suggestions for changes. I hate it when I am half way through or finish a build and someone suggests something obvious that I missed...
    The photos below are the basic design by a gentleman from Madrid. He was nice enough to share it with me. It calls for two scan speak 21W/8555-01 woofers per side in a 75 liter enclosure and one 5" Audio Technology mid woofer for the mid in a sealed 12 liter enclosure.
    I was considering using some different woofers because I dont think I can come up with $1800-$2000 for drivers alone. I was thinking of Usher 8955a woofers. I can expand the internal volume to of the cabinet to 3 cu. ft. by opening up the bottom brace that originally creates a dead space for the crossovers. Bassobox Pro shows me if I heavy fill the cabinet, I can get away with that. I am not sure if anyone else has something other than bassbox pro that tells me if this will work.
    I was going to keep the money invested in the mid range. Maybe go with a scanspeak 18W/8535 for the mid. I think it will work in that anclosure and it will be a good match both in sensativity and in appearance...
    Other than that, I am gonna use veneer for the sides and make the baffle a tad thicker so I can better time allign the drivers.
    Anyone have any thoughts or comments?
  • TacoD
    • 1080
    Great pictures, I would use a 15cm mid to stay close to Sonus Faber/ Madrid version. What about the new Vifa woofers?
    I would certainly not use the 18W, nice in a 2-way but there are better/ cheaper alternatives if it has to be a true mid.
    For calculating your boxes, you can also try the HTGuide's recommended Unibox (free excel sheet). For me the simulation results of Unibox were spot on.
    Edit:
    I also see there is a 8" version of that woofer, then I would do it a complete vifa project (ringradiator tweeter, 5" mid + 2x 8"). These new woofers have the latest cones + motor assemblies. I don't think it wil be bettered by the classic Scanspeak/ Usher woofers.
    • mgrabow
      • Dec 2009
      • 30
      Vifa
      Well the graph on that 5 inch vifa looks better then the scan speak. I cant find a graph on the ushers but the 8 inch vifa seems to have a pretty steep rolloff lowe that 100 hz...
        Who is doing the crossover design work for you?
        Sounds like a fun project.
        • TacoD
          • 1080
          You have to model the loudspeakers, the measurements on a test baffle are not always a good indication of the bass response in an actual box.
          • mgrabow
            • Dec 2009
            • 30
            Crossovers
            I will be doing the crossovers myself. I will post my preliminary design for comments once I know for sure the drivers I am using
            • mgrabow
              • Dec 2009
              • 30
              Ushers Wont Work
              Well from what everyone tells me the ushers need a larger cabinet. I was thinking of the Eton 8-800's. Bassbox pro tells me they will fit. Has anyone used these?
                • 15302
                Have used the Eton 8-800, first time in the 90's. Not much Xmax, also likes a large box.
                Fairly clean cone behavior, but it's pretty big for a midrange, not that great as a woofer. In the 90's, there weren't so many alternatives with good cone designs. Motor isn't all that linear.
                • mgrabow
                  • Dec 2009
                  • 30
                  Anyone familiar with these?
                  They will work according to bassbox
                  • shon35us
                    • Jul 2009
                    • 4
                    what site did you fine those at?
                    I love that design, however I can't seem to find the link where that was posted?
