Would you recommend using UTP cable, normal cable for PC Networks, to be used as an alternative to normal speaker cables? The cable is Avaya - SYSTIMAX 4 Pair Grey UTP 1071E GigaSPEED XL Cable, high quality cable network cable. I plan to group colour conductors for the positive pole and the white conducts for the negative pole. Each conductor diameter is 0,55 mm (0.022 in).
Network UTP cable for speakers
Movies: Samsung LCD LE37A557, Rotel RSP-1066 & RMB-1075, Sony PS3, VdH D-102 Hybrid III interc, QED XT-350 & Supra Rondo 4x2,5 speaker cable, QED Qunex P75 coax, Monitor Audio Silver 5i/8i/10i speakers, REL Quake sub, QED Qunex SR-SW subwoofer cable, IXOS XHT458 HDMI, Supra LoRad, Isotek Mini Sub GII;
Music: Rega Planar 3, Goldring 1042, Vincent PHO-8, Krell KAV-280cd, Krell KAV-400xi, B&W 703, Siltech SQ-28 Classic G5 (XLR), Siltech LS-68 Classic Mk2, Nordost Vishnu, QED Qonduit MDH6.Tags: None- Bottom
Thx for you help.
UTP cable is build up with 4 pairs of 24 AWG copper. I’ll use Rotel RMB-1075 ( 5 channels x 120 W RMS) to drive an A/V kit from Monitor Audio with Silver 8i (front), 5i (rear) and 10i (centre) speakers. Silver 8i can absorve maximum of 170 W RMS and Silver 5i 150 W. For each speaker I’ll use one UTP cable as described above. Is there are minimum diameter recommended for RMB-1075 amplifier, as it can generate reasonable amount of current?Movies: Samsung LCD LE37A557, Rotel RSP-1066 & RMB-1075, Sony PS3, VdH D-102 Hybrid III interc, QED XT-350 & Supra Rondo 4x2,5 speaker cable, QED Qunex P75 coax, Monitor Audio Silver 5i/8i/10i speakers, REL Quake sub, QED Qunex SR-SW subwoofer cable, IXOS XHT458 HDMI, Supra LoRad, Isotek Mini Sub GII;
Music: Rega Planar 3, Goldring 1042, Vincent PHO-8, Krell KAV-280cd, Krell KAV-400xi, B&W 703, Siltech SQ-28 Classic G5 (XLR), Siltech LS-68 Classic Mk2, Nordost Vishnu, QED Qonduit MDH6.- Bottom
