Speaker repair glue for drivers
  • John Holmes
    • 2703
    I have four drivers that have seperated the cones from it's rubber surrounds. I am pretty strapped for cash right now so, I cannot replace them for awhile.
    I was wondering if this http://www.partsexpress.com/pe/showd..._ID=9908&DID=7 has been used by anyone with success?
    • 15296
    Unfortunate that they don't describe what it is. However, though it might "look" like plain ole Elmer's, it also looks like the white glue which came with my refoaming kits with which I repaired my Audax 12" drivers when building my X1 SLAMM Klones.
    So, since they're selling this expressly for the purpose, there's a pretty good chance it will be OK.
    Certainly worth a shot- not much to lose. Good luck getting them running. What kind of drivers are they? Home or automtove?
    -Jon
    • John Holmes
      • 2703
      Thanks Jon,
      This was my first thought too! That is why I asked the question. As you pointed out, the cost is no more than a value meal thus, no issue there. I was just curious as to if it was worth the effort.
      As to the type of speaker. It's for my di/bipole Fosgate SD-180's. I believe they house a Morel for it's woofs. I think the heat in Baton Rouge caused the glue to fail. Our AC was out for a few days but, I ran the HT anyway . There where a few days of mid 90's. I can't imagine what the temp in the dedicated room with no windows were. Initially, I was going to order one b/c that's all I thought I needed. Then I decided to check them all. I found the adhesive failed on each woofer.
      I'll go ahead and give it a shot.
        • 1345
        I've used some white craft glue from Michaels (crafts chain). I can't remember the brand - plastic squeeze bottle, gold label. Anyway, I tried it because it didn't seem to get brittle hard like Elmer's. Coincidentally, it smelled just like the stuff that NorthCreek sells for cabinet dampening.
        I found it - Aleene's Tacky Glue: http://www.craftsetc.com/Store/Product.aspx?c=5&p=154336
        • John Holmes
          • 2703
          Thanks Hank! I'll check that out as well.
          • John Holmes
            • 2703
            Just thought I would let everyone know. I did try standard elmer's glue with great success. The drivers have been working perfectly for a yr now and still going strong..
            These are surround speakers that are x/over at 80hz.
            • cdwitmer
              • 136
              I just used plain old Elmers type PVA glue to re-edge a pair of Pioneer woofers with "carbon graphite" polymer cones. At first I thought, "This will never work, as they are non-porous." But then I noticed the outer edges of the cones had a rough surface where the surrounds overlap, so I figured, "What the hey," and just did it. So far it seems to be holding just fine. I have a lingering worry since these are sealed cabinets and I assume there is more force being applied to the joint by air pressure changes than if the cabinet design was bass reflex. We shall see how they hold up over time. However, the alternative in my view was to use either a contact cement or a resin and hardener combination, and I didn't want to get involved with those.
              • John Holmes
                • 2703
                This was my concern as well. But, it has held very well in my sealed di-poles. Glad to hear it has worked for you as well Cdwitmer. :T
