M8a MKIV ver 2
    • 16507
    M8a MKIV ver 2
    As some of you know I went ahead several months ago and built four of Jon's M8a speakers. I opted to go sealed since I had two large tempest subs to cover the low end. Anyway I was very impressed with them for the most part but I couldn't get them to blend over to the subs as well as I'd wanted and since I was looking for a new project to keep me out of trouble I decided to rebuild two of them into the ported version. With a little help from our esteemed guru's I set to work last weekend and built some new box's and since I was home with the flu today I installed the XO's and drivers and fired them up. I've been listening to them for about an hour now listening to how they sound with a port instead of sealed and running with the sub set to off in 2 channel mode. To be honest I wasn't sure how much of an improvement it would be but they're incredible! I was very happy with their soundstage before but now I think its even better and of course without the sub to interfere with the bass that's significantly better too. I'm now wondering if I had too much stuffing or maybe to little in the sealed box to explain some of the sound differences but regardless I'm one happy M8a owner 8) They're still just raw MDF at the moment but it shouldn't be to bad finishing them up from here. I'll try and borrow a digital camera in the next few days but basically the new speakers are simply two sheets of 3/4 MDF that I had cut lenghts wats to either 14.5", 10.5" or 13" for the various sides as well as a bunch of smaller peices to act as tops, seperators and bottom plates. The only snafu I ran into is since I was ripping the sheets sideways I figured the 48" width was perfect for what I needed....any it woul have been had both sheets been 48" wide :evil: Yup you guessed it I happened to grab one that was 49" and one that was 48" so I needed to do a little triming on the wider sheet. Luckily the way I had laid out the panels most of them were cut on the 48" sheet and only some of the side cheeks were on the wider sheet so they weren't as critical
    Glad you like the results Andrew. The M8a driver puts out a surprising amount of LFE for an 8" unit.
    BTW I've never seen 48" wide MDF
      • 16507
      As I promised here's some prelim pictures of the speakers as I continuing to finish them.
      I decided to do something similar to sonus Faber with the leather on the front, top and back with wooden sides. At the fabric store I found two thin faux leather fabics that I like one was basic black leather and the other was a ostrich pattern that I quite liked so that's what I choose to use.
      Here's 3" flared vent that I have on the rear of the speakers.
      Here's the grill frame I cut out. Its 1/2 MDF that I cut down to size then used the router to round the top and bottom into an oval shape then made to circle cut outs in the centre for the driver and tweeter. I then rounded over the top edge with a 1/4 round bit and painted it flat black. I also inserted four magnets that I'll use to keep the grill in place. The next step is to attatch the grill cloth to the frame. I got a few ideas on how to do that but it will depend on if I can find the right router bit to cut out a thin groove in which I can stuff the fabric and the thin rubber "pipe" they use on window screens.
      here's a shot of the nekkid MDF box's prior to applying the leather front. As you can see I've recessed the driver cutouts.
      Here's the side view showing the position of the flared port and the input cup on the bottom. I haven't attached the side peices yet since I haven't painted them at this point...in fact one still needs to be sanded down.
      Here's the front view with the Vifa tweeter installed. When the hi-Vi driver is pushed in it should snug up the leather around the tweeter nicely.
        • 8938
        I like this Andrew! The faux leather will be a nice touch. I'm very interested to see how (if any) that changes the sound of the M8A's.
        David - HTGuide flunky
        Our "Theater"
        Our DVDs on DVD Tracker
          • 16507
          I plan to add the felt around the tweeter directly to the grill frame so I imagine there will be a slight difference between running them with and without the grills on.
            • 1345
            Andrew, nice creativity at work there! Man, I wish there was a way to avoid the felt thing - IMO, chunks of felt ruin otherwise beautiful cabinets.
              • 16507
              Hank you won't see the felt at all since it will be built into the removeable grill...so when I remove the grill you will only see the leather.
                • 1345
                Andrew, I was speaking of grill off. Some people don't even use grills, some remove grills for critical listening. A beautiful cabinet with no grills looks great, and some drivers look good too.
                  • 16507
                  I'll propbably leave the grills off until the baby is tall enough to reach the M8a driver Luckily that gives me about 12 months from now :P
                    • 16507
                    I finally finished painting the side cheeks for my new towers and have been glueing them in place the last 24 hours so here's some pictures to bring you all upto speed. Click the image to view a much higher resolution version..sorry about the images its pretty dark in my HT room and I can't left these anymore to take them upstairs to the natural light. The sides were painted with numerous coats of various paints trying to get the right look. I first tried spraying on Rustoleum's "black" hammered paint which I couldn't get to look uniform (I generally don't like spray paints) I then ran out and the wal-marts were all out of the black so I tried a different brand (Tremclad) and their charcoal turned out silver which didn't look right at all so I then bought a can of the rustoleum hammered black and rolled on two coats which worked much better.
                    This one doesn't have a larger version but gives you some idea of how they look altogether.
                    Front view
                    here's how the grills turned out.
                    Here's a close up of the top showing the side cheeks and the nice ostrich leather. Its a little greener here then in real life due to the flash.
                    • Bing Fung
                      • 6521
                      EXXXcellent Andrew! The Finish material is a nice custom touch.
                      Bing
                      Bing
                        • 16507
                        thanks bing coming from you that means a lot. One of these days you and christine will have to come by and hear them
                        • Burke Strickland
                          • Sep 2001
                          • 3161
                          Cosmetically, those speakers are turning out very nicely. I hope that in use, they end up sounding as great as they look!
                          Burke
                          PS -- good use of that new camera too.
                            • 27461
                            Lookin good Andrew. Nice work! :T
                            Lex
                              • 1345
                              Andrew, they look great. If you can take a pic that shows the leather in its real color, that would be cool.
                                • 16507
                                Hank the picture further up in this thread is pretty close to how it really looks. (i.e. click here)
                                • efarstad
                                  • Jun 2001
                                  • 2231
                                  Purty speakers there Andrew...nice job! :T
                                  E
                                  The Norwegian A/V Nut!
                                  E-Cinema
                                  E-Cinema
                                  • David R.
                                    • Apr 2003
                                    • 90
                                    Andrew how did you end up attaching the grill cloth to the frame? I don't see any staples.. Did you end up routering a grove into the frame like you said above? Can you give any better details on how you did this?
                                    • David R.
                                      • Apr 2003
                                      • 90
                                      Never mind.. I read your grill cover.. post.
                                        • 16507
                                        Yes that's exactly how I did it...works extremely well
