Center Channel Design considerations
  • mikey15
    • Jun 2008
    • 23
    What effect would using sealed woofers and vented mids in the same speaker. Is it a rule of thumb to stay with one in the same design or is ok to mix.
    EDIT by moderator to merge 3 threads on the same subject
  • mikey15
    • Jun 2008
    • 23
    RS225 or Seas L22RNX/P
    Trying to settle on the drivers so I can move on. Will be a WMTMW 3 way design. I'm going to use the Zaph ZA and use his waveguide seas tweet mod. I can't get too large I only have 28L for each W. I modeled it and it looks to funky in ported so I'm thinking 18L sealed. Zaph recomends porting his ZA's would it be weird to have sealed and ported alignments in the same speaker?
    Mike
    • mikey15
      • Jun 2008
      • 23
      Center Channel config
      Want do either a WMTMW or WMTW center channel. What are your thoughts. In a 3 way design are there still lobing issues in the mids? crosover points ~250 and 2000. Center to enter distance on the mids ~6". Why woul one do a WMTMW over a WMTW. My mains will be a WMTMW.
      Mike
        How is it you only have 28L per woofer? And then you only have 18L sealed? I think 30L sealed is where the RS225 lands (?) not sure on the Seas. They're both good.
        I guess I'm weird, I design the final box after choosing the drivers and evaluating what kind of volume they like. :P
          The lobing issues are most prominent on the mids for a horizontal layout, which is why WTMW is recommended (or the MTM vertically stacked for a center).
          Center carries more dialog, more stuff on the mids - having two increases radiating surface, reduces the effort they make individually to move air - plus the changes in vertical lobing if you go MTM vertically...
          Why do you keep opening new threads for questions regarding the same project?
          • mikey15
            • Jun 2008
            • 23
            Sorry I don't really know forum rules I'll try to start a new project thread I have been wavering on design ideas
            Thanks for your help
            Mike
            • 1Michael
              • 293
              There is no point in venting a mid...
              Michael
              Chesapeake Va.
              • mikey15
                • Jun 2008
                • 23
                I have been trying to find what volume the speakers like but I also figured that 28 or 30 L is the max to keep the speaker from getting 2 deep
                Here are the graphs on the RS225 with 18L and 30L I guess I'm still really new because I'm not seeing the benefit of going larger either way it looks like it hits x-max at about 60hz
                  Just how Q changes the sound.
