All,
I simulated all of the TD15 series woofers from AE speakers and came up with the following as a short form for basic 2pi sensitivity, extension and box size:
TD15M
(97/98db) 1w/2.83v
f3 = 42.59
f6 = 37.08
f10 = 32.29
160.8 liters vented
TD15S
(93/95db) 1w/2.83v
f3 = 44
f6 = 33.5
f10 = 25.17
177 liters sealed
TD15X
(94/96db) 1w/2.83v
f3 = 57
f6 = 38.47
f10 = 27
151.36 liters vented
TD15H
(93/94db) 1w/2.83v
f3 = 38.47
f6 = 32.59
f10 = 27.6
101.2 liters vented
My questions are...what are the differences in sound quality between the different cone/surround materials? And could a lower sensitivity/same power handling version of the TD15S be built? Ideally I want a 15"/500w version of the Scan Speak 25W/8565-00. I can't name the part that I am mating it to (under NDA or something like it), but the woofer will be used in a 3 way with the mid running down to ~250-300 hz.
(This is a NON-commercial post and is for DIY use only)
TD15M
(97/98db) 1w/2.83v
f3 = 42.59
f6 = 37.08
f10 = 32.29
160.8 liters vented
TD15S
(93/95db) 1w/2.83v
f3 = 44
f6 = 33.5
f10 = 25.17
177 liters sealed
TD15X
(94/96db) 1w/2.83v
f3 = 57
f6 = 38.47
f10 = 27
TD15H
(93/94db) 1w/2.83v
f3 = 38.47
f6 = 32.59
f10 = 27.6
101.2 liters vented
