accuton...FYI
  • chrismercurio
    • 116
    accuton...FYI
    new products
    new site
    If you have to ask...
    • 1038
    To my untrained eye, the big diamond "mid range" looks interesting in a sort of platypus way. It would seem like it would be too big to have decent off-axis response up high (it is also listed as a tweeter), and the performance into the mid-bass area isn't great. Seems like this is either for an ultra high-end loudspeaker that still has a bottom that works to >1k, or its for a an ultra high-end two-way that someone wants to listen to by himself.
    The big 11" "sandwich" driver seems a bit on the bizarre end. Stay well away from those speed-bump impedance bobbles. Yuck!
      • 15302
      Finally they've got a decent web site up as opposed to the last attempt that had hardly been updated since 2005!!
      Still, some of the data is confusing- like listing "diameter" for tweeters, and they have to be referring to the casing size, not the radiating diaphragm size.
      Wish I could afford a pair of the BD30-6-036, I expect the 11" sandwich drier is only meant to be used up to 400 Hz or so.
      This is such a huge improvement over the last version of their web site.
      C78 is an interesting addition- wonder if that's been an OEM part only?
      • Winter
        • Nov 2007
        • 81
        Check out the distortion graph on the C173-6-096E. The C90-6-079 is very good also.
        • TacoD
          • 1080
          Is the C78 not a renamed part?
            • 1038
            The TSPs look a bit different than the C173n-T6-96 at Madisound, so perhaps the next generation? Or better testing? The FR plot looks very similar. I wonder if this is the same driver that is in the Kharma speakers that the high-end press drools over. Might be an interesting cost-no-object combination with the beryllium SS tweeter.
            • Jed
              • 3621
              Very nice website! Finally they put this together. Some interesting drivers they have there, but I certainly won't be buying any of the diamond mids any time soon given the diamond 5 carat price tag that comes with it!
                • 15302
                Yeah, you probably have to have one of those Black AMEX cards to qualify for purchase...
                • chrismercurio
                  • 116
                  I don't know why, but I just thought of checking their site since I hadn't in a long while. The 11" inch is of great interest to me...but I can't spend the 1-2k each that they most likely cost.
                  Marten Design recently release a speaker with those sandwich woofers for 130k Euro...
                  • TacoD
                    • 1080
                    Which model, they already have very expensive diamond based towers.
                      • 1038
                      I think that would be the Coltrane Momento, but those look like they are using the "standard" big ceramic woofer (listed in the product literature as a 9"). I don't see anything with the 11" in the product list or in the "news" (blog).
                      The problem, as I see it, with the 11" is the impedance bobbles that start at 1kHz that show-up, as expected, as spikes in the HD graphs, meaning something around a 200Hz Fc, depending upon slope:
                      For what these would undoubtedly cost, I expect there are comparable or better drivers that could still blend successfully with the full ceramics on top.
                      • chrismercurio
                        • 116
                        those are the new 9" sandwich cones in the newest coltrane.
                        • TacoD
                          • 1080
                          and Passive Radiator from Accuton
                            • 15302
                            Yeah, interesting and strange at the same time! The scale they use for distortion measurements tends to obscure differences below a certain level- would much rather see a log scale or dB. Such is life...
                              • 1038
                              Might be a touch too revealing to the wrong parties?
                              • kevinlin1013
                                • Dec 2010
                                • 47
                                Is Marten Design's 9"woofer as C220? Though C220 series are called 8".
