I know we have a ton of finishing threads. That really does make this forum one of the most valuable in my mind for building speakers. However, I have a question about what to do with errors already made.
As careful as I tried to be, I still managed to get a tiny bit of glue on the veneer face. I used a wet rag to wipe up one small spot. Another went unnoticed until it dried (a drip). :M
So now I am at a conundrum. The veneer in question is african ribbon mahogany and I had intended to use shellac + anoline dye (thanks to this forum) to go for a bombay mahogany look. I like it dark. Now I am afraid that I will have small spots that won't take the dye.
So do I forget it and just finish with straight shellac? Or is there anything that can be done about either or both flubs? Anything that can clean up a post-humous glue drip?
I am planning to make a scrap piece of wood with veneer on it for experimenting with the dye to get what I was looking for, I could try to recreate the botches and see how they take the dye and how bad it might look.
Another idea I had was to try to lightly burn the small areas that had glue so it looks like a more natural wood defect and go ahead with the dye. It would look more natural than a light spot.
