Since John is an advertiser on the mail HTG page, I told him we could post this here.
IF you have questions on the drivers, I suggest starting a new thread so we don't loose focus on the pre-orders.
I am sure John would be glad to stop in and answer any questions you may have.
Special Pre-order now at Stryke on these. If you decide to order some, and you saw it here, post here that you are "in" and how many. When everyone (if anyone) signs up, I will present John with the mass order, though you all will follow up with Stryke with Payment and shipping info...
Images available Sept 18. Looks to be a winner!
Thanks!
Lex
DRIVER: AV12 T/S 12" driver
SPECIFICATIONS:
Fs: 21Hz
Qms: 4.41
Qes: .399
Qts: .366
Vas: 88 L
Re: 2.97 ohm
Z: 4 ohm
BL: 15 Tm
Cms: .25 mm/N
Mms: 228 g
Pe: 500W
1W/1m: 85.5dB
2.83V: 89.5dB
Xmax: 23.4 mm
Xsus: 30 mm
Sd: 498 sq cm
LIST PRICE: 175.00
140.00 preorder NOW
AV15 T/S 15" driver
Fs: 19.7 Hz
Qms: 4.71
Qes: .399
Qts: .368
Vas: 228 L
Re: 2.97 ohm
Z: 4 ohm
BL: 15.5 Tm
Cms: .25 mm/N
Mms: 260 g
Pe: 500W
1W/1m: 88.5dB
2.83V: 92.5dB
Xmax: 23.3 mm
Xsus: 30 mm
Sd: 802 sq cm
Vd: 3.8 L
$205 list price
$165 preorder!
After much anticipation, the new "bang per buck" champions are here. We have been working long and hard, along with TC Sounds, "The Leader in High Excursion Bass Drivers," to produce a new affordable option for those who are looking for a high quality, high excursion woofer, without the high price tag. What we came up with are our new AV12 and AV15 woofers.
We started with a standard TC Sounds motor design that has been long proven in the industry. The AV12 and AV15 utilize a specially designed 2" diameter, 2.1" long VC and a .5" thick gap plate. This gives 20.32mm of VC overhang, and allows for a measured Xmag of 23.4mm. A 12 spoke cast aluminum basket was chosen for it's strenght, and adequate venting under the VC to aid in cooling. This venting in the basket, and the specially designed VC give this woofer power handling that far exceeds that of standard 2" VC woofers.
Thanks!
Lex
SPECIFICATIONS:
Fs: 21Hz
Qms: 4.41
Qes: .399
Qts: .366
Vas: 88 L
Re: 2.97 ohm
Z: 4 ohm
BL: 15 Tm
Cms: .25 mm/N
Mms: 228 g
Pe: 500W
1W/1m: 85.5dB
2.83V: 89.5dB
Xmax: 23.4 mm
Xsus: 30 mm
Sd: 498 sq cm
LIST PRICE: 175.00
140.00 preorder NOW
AV15 T/S 15" driver
Fs: 19.7 Hz
Qms: 4.71
Qes: .399
Qts: .368
Vas: 228 L
Re: 2.97 ohm
Z: 4 ohm
BL: 15.5 Tm
Cms: .25 mm/N
Mms: 260 g
Pe: 500W
1W/1m: 88.5dB
2.83V: 92.5dB
Xmax: 23.3 mm
Xsus: 30 mm
Sd: 802 sq cm
Vd: 3.8 L
$205 list price
$165 preorder!
